UNIVERSITY-SOUND 583 SCH.
8.3 KB
Looking for similar university manual?
    583 SCH. SOUND
bp-PgAlfaFiat
Kedves kollégák letöltöttem az oldalrol a Bp-PgAlfaFiat kodfejtő progit de 3-4 használat után regisztrácios kodot kér (name:,key:), tud e valaki segiteni ebben?
Sony ps-lx431 lemezjátszó karlift
Sziasztok! Érdeklődnék nincs Valakinek a lift környékéről anyaga? (robbantott ábra , fénykép) Az okos szétszedte, és bezacskózva hozta hozzám, hogy rakjam össze. Köszi.
Digipro 1000 amp
Hello. I’m new on forum. I have blown amplifier digipro 1000 from DB technologies. I found some bad parts, but cannot identify this diode. It has marking 31. In wiring it is d12 and d13. Scheme is there: https://elektrotanya.com/cgi-bin/download2.cgi?uid=19628&cid=1541665480&fid=289613&file=db-technologies_s10_sch_pcb.pdf&x=28&y=15 Thank you in advance.
ONKYO amplifier dolby surround, Problem with a Switching Diode
Hi everyone
Could somebody tell me if I can replace a switching diode to another one, the one installed in the onkyo is a 1SS252 and is 10 times more expensive that a 1SS355.
Usually I order the same but they are pricey (around 10.00 usd for a 100) and not commonly used, not many sellers.
For the 1ss355 every seller on line has it in stock and it's around 1 to 2 usd for a 100.
Ans they are available locally, not in china waiting 5 weeks for the part.
Thank you.
1SS352
Characteristic Symbol Rating Unit
Maximum (peak) reverse voltage VRM 85 V
Reverse voltage VR 80 V
Maximum (peak) forward current IFM 200 mA
Average forward current IO 100 mA
Surge current (10ms) IFSM 1 A
Power dissipation P 200 (*) mW
Junction temperature Tj 125 °C
Storage temperature Tstg −55~125 °C
1SS355
Maximum (peak) reverse voltage VRM 90 V
Maximum (peak) forward current IFM 225 mA
Surge current (1s) IFSM 500 mA
Junction temperature Tj 150 °C
Storage temperature Tstg −55~150 °C
