VADASZTOLTENY-R656-BALATON CSOVES RADIO.
30.2 KB
Looking for similar vadasztolteny manual?
    CSOVES RADIO. 656 BALATON R656
Keresek CXA1081S-t
Sziasztok! Keresek a címben szereplő, bontott ic-t. Tudom, hogy a S-ben van, de nekem emberi áron kellene. Sony CD lejátszó elektronikákban szokott előferdülni.
ONKYO amplifier dolby surround, Problem with a Switching Diode
Hi everyone
Could somebody tell me if I can replace a switching diode to another one, the one installed in the onkyo is a 1SS252 and is 10 times more expensive that a 1SS355.
Usually I order the same but they are pricey (around 10.00 usd for a 100) and not commonly used, not many sellers.
For the 1ss355 every seller on line has it in stock and it's around 1 to 2 usd for a 100.
Ans they are available locally, not in china waiting 5 weeks for the part.
Thank you.
1SS352
Characteristic Symbol Rating Unit
Maximum (peak) reverse voltage VRM 85 V
Reverse voltage VR 80 V
Maximum (peak) forward current IFM 200 mA
Average forward current IO 100 mA
Surge current (10ms) IFSM 1 A
Power dissipation P 200 (*) mW
Junction temperature Tj 125 °C
Storage temperature Tstg −55~125 °C
1SS355
Maximum (peak) reverse voltage VRM 90 V
Maximum (peak) forward current IFM 225 mA
Surge current (1s) IFSM 500 mA
Junction temperature Tj 150 °C
Storage temperature Tstg −55~150 °C
looking for service manual: Cambridge Audio Stream Magic6 v1
Hi,
I am looking for the service manual "Cambridge Audio Stream Magic6 v1" or the schematic of the power supply.
Thanks in advance
Phil
Samsung MM-D330/EN mini hifi zárlat (megoldva)
  Sziasztok! Van itt egy ilyen, a secunderben pár alkatrész leégett, vagy zárlatos. Más alkatrészt rossznak nem találok. Vajon elég lesz ennek a cseréje, és megjavul?
(Graetz, tárcsakondi, bizti)
Tudom próba cseresznye, köszi :)
