üdv: szerencsétlenségemre belebotlottam egy ilyen Z mechanikás készülékbe.
F04 hibát jelzett. A töltőmotoron levő négyágú kuplung repedt volt, megjavítottam, egy antennacsövet szorosan rásajtolva. A nyomógörgőt is a helyére tettem, a leszorító műag. idommal együtt.(zacskóban hozták)
9 V-os külső tápról normálisan ki-be megy a mechanika
A vezérkeréken a nyíl "kazetta kint állásban " felfelé mutat, alatta a forgókapcsoló illeszkedik.
Kazettát betéve nem indul, továbbra is F04-et mutat.
Ennél az alappozíció a "kazetta kint", vagy "kazetta lent" állásban van?
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Videomagnók alkatrésznek 2000Ft/db.
-JVC HR-V507 kazettafészek hiba
-SCHNEIDER SVC618 kazettafészek hiba
-HITACHI VT-M747 szervó hiba
-SONY SLV-SE 727
-PANASONIC NV-HD650
-PANASONIC NV-SD270
Subject hozzám került. Ez egy kommersz alsókategóriás régi videó lenne. Először el sem akart indulni. Mikor szétszedtem akkor jött az első meglepetés: Nem kapcsolóüzemű a tápja. Egy öklömnyi trafót raktak bele. Szerencsére csak a szekuder oldali nagy puffert kellett kicserélni és magához tért.
A következő probléma akkor adódott mikor kazettát akartam belerakni. A négy szíjból 2 elszakadt, a másik kettő meg laza volt mint a rigalánc. Vettem hozzá szíjkészletet, 700 forint volt (kb. a videó értékének 700szorosa). Szépen magához tért, kazettát bevesz, pörget.
Most viszont megakadtam, mert van egy fura hibája. A szalag elején szépen működik minden, de ahogy egyre inkább a végére ér kezd belassulni a csévélés, néha hallhatóan lelassul, meg-megáll egy pillanatra, amíg végül teljesen megáll, nem továbbítja a szalagot és kikapcsol.
A nyomógörgő gyanús nekem, mert meglehetősen kemény. Sini tartja, egy ezresért. Ennyit már nem kívánok rá költeni. Van valakinek ilyen esetleg?
![](/files/g.jpg)
Esetleg előfordulhat, hogy nem a görgő, hanem inkább a kuplung a hibás? Mit érdemes ilyenkor még ellenőrizni?
Megint egy videó mechanika... Jaj. :)
DM
