ACER 1566
MONITOR - EPROM
965.0byte
MONITOR
EPROM
Looking for similar acer manual?
    ACER 1566
ACER AL1917As LCD monitor
Üdv Mindenkinek! A témában megnevezett monitorhoz keresek táp-inverter panelt, de egy inverter trafó is elég lenne! http://kepfeltoltes.hu/view/081215/DSC06913_www.kepfeltoltes.hu_.jpg Köszönöm előre is! esaman
Acer V223HQ - ILPI-075 Rev.A power supply turns off
Hi, I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there. I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank. I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off. The HV side of inverter transformers is about 470 ohm, they look OK. I measured random capacitor in the +16V line, which is supplying the high voltage inverters. We can see how the voltage went down while the backlight was powered on. Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off. I don't have any idea what to check now..
acer AL1731 hibás vezérlő panel
Sziasztok acer al 1731-es monitorhoz keresnék AM939 VL903-as controll panelt illetve AM939 VP903-as táp panelt aki tud segiteni kérem jelezze. üdv "FONTOS! Olyan fórum téma nevet válassz, ami beszédes, minél pontosabban illeszkedik arra, amivel kapcsolatban írsz. Egy lehetséges jó elnevezés pl: ORION LCD PT26S chassis 17MB12-2, a tápja nem indul Az nem elég, hogy pl: "LG LCD-TV" vagy "HP laptop" és hasonlóak. Illetve érdektelen, nem releváns információt se tartalmazzon a cím! A helytelenül elnevezett topik felfüggesztésre kerül! Nem lehet majd hozzászólni, amíg ki nem javítod a címet. A hibás cím utólagos javítása a "Szerkesztés" fülre kattintva végezhető el."
ACER AL-1715 monitor tipushiba, bepirosodó kép
üdv Van két ACER AL-1715 tipusú monitorunk mindkettő ugyanazzal a hibajelenséggel, nevezetesen: időnként elpirosodik a kép majd egy idő elteltével visszavált rendes képre és megy tovább mintha misem történt volna.És ez ismétlődik véletlenszerűen. Amugy minden látszik rajta rendesen csak pirosas árnyalatot kap a kép. Ha találkozott már valaki ezzel a hibával mondja már el nekem általában mi okozza ezt a hibát ,hogy kevesebb időt kelljen hibakeresgetni.(A SM-ja megtalálható feltöltve.) köszi sandor
