ACER 7135C EPROM
MONITOR - EPROM
292.0byte
MONITOR
EPROM
Looking for similar acer manual?
    ACER EPROM 7135C 7135
ACER AL1916W hez keresek lcd panelt (T)
Üdv mindenkinek. ACER AL1916W hez keresek lcd panelt. A komplett panel tipusa LTM190M2-L31 samsung
Acer 1916WA monitor képhiba miatt letilt
Sziasztok! Acer 1916WA monitoron az alábbi kép látszik pár pillanatra, majd letilt. Szerintem T-con, vagy kijelzőhiba, ami az eredmény tekintetében majdnem mindegy. Jól látom, vagy tévedek, és van más megoldás? Köszönettel Attila Ui.: A második kép nem tudom, miért kék, ugyanazzal az eljárásal, ugyanúgy készült. A lényeg: a kép felső része fehér, ott csak halvány pirosas csíkok látszanak függőlegesen.
Acer V223HQ - ILPI-075 Rev.A power supply turns off
Hi, I'm sorry for writing in English, but I don't understand any single word in Hungarian and I couldn't find an English subforum there. I have changed the LVDS controller and now it's working perfectly, but I need help with the backlight. The CCFL lamps in the screen are OK. I connected the screen to another inverter (from BenQ T705, made on TL1451 which also has "protect" function) and the backlight worked perfectly. Again, I connected other screen to the malfunctioning ILPI-075 inverter and the screen also goes blank. I changed all THT electrolytic capacitors on the board, but not much has changed. Before, the backlight was turning off almost immediately, now it glows for 1-2 seconds and then turns off. The HV side of inverter transformers is about 470 ohm, they look OK. I measured random capacitor in the +16V line, which is supplying the high voltage inverters. We can see how the voltage went down while the backlight was powered on. Also, the ON/OFF signal on ICL837's pin 8 is always present after powering up the power supply, even after the backlight turns off. I don't have any idea what to check now..
Acer 1715 Mozaikos
Sziasztok. Van nálam egy Acer monitor és az a hibája ,hogy a képernyőn mozaikba jelenik meg a kép. Egy napig megy szépen másnap bekepcsoláskor mozaik ,erre 230 kihúz visszadug és megy szépen. Hátha valaki tudja a megoldást .Előre is köszi.
