ALWAYS DE LUXE-SUPER 41 1940 SCH
Type: (PNG)
104.7 KB
Looking for similar always manual?
    ALWAYS DE LUXESUPER 41 1940 LUXE SUPER LUXE-SUPER
Receiver Denon AVR1311 starts On and after 8 seconds shut down automatically...
Hello everybody, This receiver starts normally and has a nice blue display lighting on for 8 seconds. Suddenly you ear the main relay falling down and everything turns off and you get the red led flashing around the main power switch button. There is no special code with this continuous flashing rythm of the led. I have no diagram of the device and I have opened it and measured the voltage on pin 4 of the voltage regulator KIA78R05P1, which has a validating signal on his pin four.(2 is the output and 3 is frame (-)).this 5V(to-220)monolithic 7805 regulator is on the main PCB, close to the little transfo and ON/OFF relay...and is mounted without any heat dissipator(I was surprised of that fact!).the voltage between(4-3)is 1,88V dc and never climbs up during the starting sequence. Can you help me to solve this problem?
Renault laguna kijelző bekötése.
Renault rádió kijelző: Borg 7700822081 hat pólusú csatlakozásának a leírása kellene. neten nem találtam. Köszi. Gabi
Régi hifi katalógusok+ orsós magnó múzeum
Rengeteg katalógus, vannak kapcsolási rajzok is http://wegavision.pytalhost.com/ http://www.magnomuzeum.hu/index.php?inf=fotoalbum
behringer pmp5000
Hello
PMP5000 keverőpult mono csatornáin 1-12 a gain csak az utolsó 5 % ban szabályoz.Találkoztatok e ezzel a problémával?
A +-15V  táp rendben van. Labortáppal próbáltam.
