I have and found most of the voltages as indicated on the circuit diagram, till op amp M 5218P; are near those specifed. The output on the centre of the two power transistors of both the channels are also alright.
While looking at the voltages on test points as mentioned on the page 7 for setting up quiscent current, these cannot be set.
Bit of history, the amplifier was lying unused for long time. Nothing in it has burnt. It was never opened earlier than this time, couple of days back.
While I was probing for voltages with DMM, with probe on collector of TR413 one of the fuses blew up. Later same thing happened on the other channel as well.
With the above as background can a Good Samaritan figure out feasibility of repair.
i am unable to upload service manual as file size is 7.3 mb
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Üdvözlet mindenkinek.Egy Magnat Xcite 560-assal küzdök.A végfok tranzisztorai B778 és D998.Ilyeneket sehol sem találok.Kérem segítsen valaki azzal,hogy megírja a helyettesítő alkatrészek típusát,amit kapni is lehet valahol,vagy esetleg olyan készüléket,amiben ugyanez van,hátha tudok szerezni valahol egy rosszat,amiben van két jó végfoktranzisztor.
Előre is köszönöm a válaszokat.
