For your information to repair
Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown)
can be changed without any other servicing
Harman Kardon Receivers; Series AVR 2000,3000...
"Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time.
"Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V.
"Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there.
"volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V!
"everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function.
Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts.
So i hope i can help you...
cheers SG.
Kedves szakik, kaptam egy a címben említett erősítőt, amelynek első megitélésre végfog gondja volt megrendeltem bele a 2db új végfokot és olyat produkál hogy bekapcsolás után elkezd búgni majd kb 10mp eltelte után a erősebben kezd és a hangszórók membránja kifelé mozdul, tovább nem mertem bekapcsolva hagyni, de hangot nem ad ki hiába kötöttem a bemenetére jelet, nem találkoztam ég efféle jelenséggel, ha valaki tudna segíteni ebben azt szivesen venném.
Van egy Sony STR-DE135 erosito, minden tokeletesen mukodik, egy dolog kivetelevel. A hangero allito poti jobb oldala mellett van ket mikrokapcsolo. Felul a Bass Boost es alatta a Mute gomb. A problema az, hogy amikor nyomogatom a Bass boost gombot, akkor veletlenszeruen, hol jol mukodik, hol a Mute gomb aktivalodik helyette, es van amikor teljesen erzeketlen. Ha a taviranyitorol nyomogatom ugyanezeket, ott tokeletesen mukodik. Valakinek van valami otlete ezzel kapcsolatosan? Az erosito mar ebben az allapotaban kerult hozzam, es meg sosem volt szetszedve.
Segitsegeteket elore is koszonom.
Tisztelt Fórumtársak!
A Sony ST-S120 tunerem monóban szól,de nincs sztereó jel.Automata hangoláskor,nem áll meg,annak ellenére,hogy a jelszint kijelző maximális jelet mutat. Fórumokat kutatva,azok tanácsát követve,kicseréltem a következő kondenzátorokat(rajzon piros pamaccsal jelölve)
C23=47uF 50v,C24=3.3uF 63V,C28=1uF 50V,C30=1uF 50V,C31=0.47uF 50V,C32=0.1uF 50V,C37=10uF 50V,C38=10uF 50V,C38=10uF 50V,C38=10uF 50V,C41=4.7uF 50V,C43=220uF 16V,C51=47uF 50V.
Így sincs sztereó jel. Egy lengyel oldalon azt írta valaki,hogy a LA1851N-ben a sztereódekóder rész tönkrement cserélni kell.Kicseréltem,mégse lett jó..Az IC-én a feszültségek rendben vannak.Az LC7218-as IC-nek kellene leállítani a VCO-t,de nem teszi.A két tranzisztoron(Q23,24) még nem ellenőriztem a jelet,arra gyanakszom talán azok,vagy a LC7218-as IC környékén kell keresni a problémát? Ha az a hiba,akkor lesz sztereó jel is? Előre is köszönöm a tanácsotokat,javaslatotokat!
Üdvözlettel: Feri
