Hello,
I have a washing machine (Bauknecht WAK74 (8583 642 03011) ) that had an F8 error due to a bad heating element. After changing it, the washing cycle (also the test program when hitting the "löschen" (delete) button a couple of times does more or less ) runs through, it is heating fine, but the F8 error is still being displayed.
I checked, cleaned, enhanced all the contacts, also of various other places I could reach to make sure it won't detect it e.g. due to vibration shortly causing a higher impedance.
I am a bit out of my comfort zone here (usually doing industrial stuff) so not having any experience with the brand and only service manuals from similar machines I am not quite sure if
- there is something else that could cause the F8 error that happened during the repair.
- there is a procedure needed to reset the error from the machine
- the error is really triggered each time the program (or test) runs, or if it is saved in the eeprom
Unfortunately I don't have a "clean" eeprom to just overwrite the old one. One test I did though was disconnect the NTC, leading to another error, then reconnecting it. The test program would still display the NTC error, but after writing back the old eeprom it didn't. So my suspicion is that the current eeprom might somehow contain the F8 error and overwriting it with a clean one might be all thats needed...
( I also grabbed the µC code and tried to disassemble/decompile it in ghidra but didn't have the time to get very far with it)
Sziasztok!Sok idő elment erre a wak6752-es gépre. Az első két program majdnem lemegy,melegít,dolgozik rendesen,de az ajtót nem zárja le,világít is,Tür Frei(ajtó nyitva),a program végefele,a centri függőleges ledjei villognak,majd többször sípol és leáll.A többi programon már indulás után ezt csinálja. Gyorsmosást pl. nem tudok rajta indítani csak csippan a gomb megnyomására,de nem aktiválódik a program.Próbáltam kiiktatni az ajtókapcsolót,ill. cseréltem is de nem zár le,ill. ha zárom,kialszik a led,de egy idő után megint azt mondja,hogy nyitva van az ajtó.Centrit lenyomja rendesen. Viszont,ha az aljában lévő mikrokapcsolót aktiválom,lezár az ajtó,de nem megy a gép csak szivattyúz.Mivel alkatrészt nem találtam hibásat a panelon,én arra gondolok,hogy egy eeprom tartalom esetleg megoldás lehet.Mert végül is mindene működik,csak kicsit téveszt.Szóval nem-e volna valakinek egy mentése ehhez a tipushoz?Én keresgéltem,de nem igazán találtam.Köszönöm előre is.
Űdv. Mindenkinek . Leegyszerűsítve Wpool 6.érzék panelról van szó (ennek van külön panelon a nedvesség érzékelője ) és a fűtőröl jövő NTC ellenállással a panelon van sorba egy R66 poz. számmal smd ellenállás ami megszakadt és az értéke kellene mert nem olvasható . Tettem bele próbára 10K , de az érzésem , hogy túl melegíti a ruhákat . Esetleg jó jönne valami infó , hogy mekkora hőfok kell , hogy legyen a dobba azt megpróbálom kikísérletezni az értéket.
Küzdök ezzel a mosogatóval. 2 hete már volt nálam, tulaj nem tudta pontosan elmondani mi vele a probléma, de már egy ideje kinlódik neki. Elhoztam átnéztem nem találtam hibát, 3 program gond nélkül lefutott. Biztonság kedvééért kitakarítottam az egészet esetleges dugulás okozza-e a problémát, illetve a tulajnak is ezt javasoltam, ahová ürít azt takarítsa ki és mennie kell. Pár napig nálla is dolgozott majd ismét hív, hogy megint megállt. Program közben halt be és nem is mozdul. Elmentem megnéztem indítottunk egy új programot és most már valóban produkálta a hibát, mégpedig azt, hogy a víz beeresztés után szaggatva indítja a keringetőt. Olyan mint ha valaki kapcsolgatná, hol ráadja a feszültséget hol elveszi. Megindul, majd megáll, kicsit gondolkozik újra megindul de csak egy pillanatra aztán megint megáll és így tovább. Keringetőt levettem direktbe meghajtva gond nélkül, tengely nem kotyog nem tűnik halottnak. Elektronikát átnéztem forrasztási hibát nem találtam azért a főbb részeket átforrasztottam. Pluszba az összes kondit újra cseréltem, illetve négy reléből kettőt szintén újra cseréltem.
A hiba továbbra is fenn áll nincs változás. Eddig azért valameddig elment a program, viszont most már nem hajlandó dolgozni csak megindul, megáll stb.
Valakinek esetleg ötlet vagy volt-e már ilyen hibája?
