BBK 9903S-9903S-1A
VIDEO-DVD - EPROM
673.3 KB
EPROM
Looking for similar bbk manual?
    BBK 9903 9903S 1A
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
Funai 25D 850 nem lehet TV adásra kapcsolni
Sziasztok! A fenti Funai videónak az a hibája, hogy a menübe belépve szépen be lehet programozni az adókat, de kilépve a menüből már nem lehet a programokat előhívni. Bekapcsolni lehet, de a progr. számok már nem jönnek be, ennél fogva az adók sem. A menübe visszalépve ott vannak, rögzítette. Az órát nem felejti el, reseteltem is, de nem boldogulok vele Tudtok valami okosat? Üdv Attila
SHARP VC-A30BP kazettafészek gond.
Szép estét Mindenkinek! Van ez a muzeális darab, mely szíjak cseréje és programkapcsoló pucolás, majd teljes tisztítás után hihetetlenül szépen dolgozik. Igen ám, de az okos gazdája a megevett kazettát kiszedte belőle, és elbarmolta a kazettafészek jobb oldali kiemelő fogaskerekét. Ezt viszont csak a restaurálás után vettem észre. Tehát jelenleg ha segítek a kazettafészeknek lejutni, pöpecül megy. Ki is adja a kazettát. Be viszont csak segítséggel megy. Szóval: van e valakinek ehhez a géphez kazettafészke, vagy bármilyen működő fölösleges videója? A gazdit bármi működő gép érdekelné megvételre, mert mindenáron videózni akar. Ja a lényeg! Pesti. Azaz budai. Szóval ha itt Budapesten vagy környékén lenne valakinek fölösleges gépe, annak nagyon örülne. Meg én is, mert akkor nem cseszegetne tovább!
GRUNDIG VS600 Időzítés törléséhez kérnék segítséget. (megoldva)
Sziasztok! Egy ilyen "múmia" került hozzám. Sikerült életre keltenem, (mechanika cserével) de kipróbálni már nem tudom. Az időzítés villog csupán a kijelzőn és nem reagál semmire. Emlékeim szerint (vagy húsz éve javítottam ilyet utoljára) valami "trükk" volt ennek törlésére.... Esetleg valaki tudja a megoldást? Köszönettel: Kiss Z.
