BECKER BE1801 NOCODE
CAR-AUDIO - EPROM
Type: (BIN)
256.0byte
CAR-AUDIO
EPROM
Looking for similar becker manual?
    BECKER BE-1801 BE1801 NOCODE BE 1801
Becker Mexiko autórádió keresés
Keresek nevezett készüléket hiánytalan, működő, vagy javítható állapotút.
Becker Cascade BE7944 need help!
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
 I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Mercedes-Benz special Becker BE2210 13,8V-nál kikapcsól.
Szervusztok.
Szeretnék érdeklődi,hogy mi lehet a probléma a fent nevezet készüléknél.
A motor magasabb fordulatánál a kocsi töltése 13.8V és ennél a feszültségnél a rádió Mercedes-Benz special Becker BE2210 kikapcsól.
Ha a gázról leveszem a lábam akkor vissza áll minden.
Ha valaki találkozott ilyen hibával,szeretném ha megosztaná velem.
Üdvözlettel: buszosgyuri.
Mercedes becker 2210 nincs kijelzés
Meg állt a tudomány.
Táp 8,5V és 5V rendben.
kijelzőn semmi gombokra nem reagál.
Bekapcsolom kis áramfelvétel van.
zárlatot nem mérek.
mi lehet vele?
Előélet:
Az autó több éve állt. Autóban a rádió bekapcsolt kódot kért de az első számjegyen kívül nem érzékelte a többit. Mondom roszak a gombok.
kiszedtem a rádiót szét sem szedtem de már az asztalon nem indult be.
Szétszedtem agombokból 3 valóban nem működik.
mást nem találtam
még.
