Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Van javításon egy házi gyartmanyu végerôsítô ±38V táppal, a kimeneten oszciloszkóppal nézve csak a hangjel alja (negatív része) jön ki.
Egy hasonló rajzot találtam a neten, de nálam a Q7 bázisán -37V van.
1.Nálam NPN a végfok akkor is -0.69V kell hogy legyen?
Nagyon torz a hangzása, de ha megtekertem teljes hangerôre akkor megjelent a hang felso pozitiv része is, csak hát most így elszállt a Q4 meghajtô tranzisztor a pozitiv résznél, meg a Q8 nyugalmi áramot beállitó tranzsztor.Q8-at kicseréltem és kiszedtem a meghajtókat 1.39V/-1.39V helyett 8V/-8V-ot mérek, elôtte pedig 1.39V/-1.39V volt. Most nem merem berakni a meghatókat nehogy kilôjje.
2.Lehetséges hogy mivel nincsenek benne a tranzisztorok azért van 8V?
"Hasonlo.jpg" rajz csak a végtranzisztorból nem 2x2 db van benne
Üdv. a Kollégáknak!
Az említett soundbar tökéletesen müködött mindaddig, míg át nem költöztették egyik szobából a másikba, ahol, miután üzembe helyezték, észrevették, hogy a mélynyomó hangfal nem müködik, csak pirosan világít a ledje. Nyomkodták a gombokat a soundbaron meg a távirányítón, a használati útmutató szerint, de nem sikerült cstatlakoztatni a mélynyomót.
Azután a tulaj elhozta hozzám, hogy nézzem át, hátha meg lehetne javítani. Követve a használati útmutatót, mindent megpróbáltam: vissza állítottam gyári állapoba, majd kézzel csatlakoztatni a subwoofert a főegységhez, de sajnos erdemény nélkül.
Amit észrevettem az az, hogy a mélynyomó ledje a bekapcsolás pillanatában egy pillanatra fölvillan kéken, majd pirosba megy és konstansan világít.
Belenéztem, átvizsgáltam a kondikat és jónak bizonyultak. Feszeket is mértem, talán jók - nincs hozzá kapcsolási rajzom, így nem tudom összehasonlítani semmivel. A procikon kb. 3.3 V van. Lemértem a BEKEN procik kvarc frekvenciáját és pontosak: 24.57 Mhz. Két féle feltételezésem van, éspedig: a méynyomó hangfal nem veszi a rádió jelet és készenléti állapotba megy, a másik, az, hogy a központi egység, a soundbar nem ad le jelet a hangfal felé, így ennek nincs mit észlelnie, tehát nincs mihez kapcsolódnia. Vagy talán firmware hiba van? Valami miatt meghibásodott a program és nem találja a hangfalat? Melyik a valószínübb? Ebben szeretnék segítséget kérni azon kollégáktól akik már találkozatk ilyen, vagy ehhez hasonló problémával és sikerült megoldaniuk.
Zsolt.
Drága édes apukám felhívott,hogy nézzem meg a fent nevezett hőn szeretett rádióját mert kicsit furcsán lehet bekapcsolni!Még pediglen úgy,hogy bekapcsolja a rádiót és semmi de ha lenyomja közben a magnó valamelyik gombját akkor szól a rádió!
Természetesen mint egy jó gyerek egyből felajánlottam,hogy megnézem és szétszedem,természetesen még hozzá tette,ha lehet akkor legyen belőle még rádió :lol: nem is tudom mire gondolt talán gyerekkoromban is szereltem neki valamit :hmmm:
De a viccet félretéve természetesen átnéztem a rádiót és átméregettem a rajz szerinti feszültségeket amik rendben is lennének,de a hiba tulajdon képen a kapcsolóban van,természetesen,hogy pont isostat kapcsoló van benne ha jól emlékszem a nevére!
A kérdésem az lenne,hogy valakinek nincs ilyen a rádióba való kapcsolója?
Mert akkor vevő lennék rá,édesapám meg örülne,hogy végre nem csak szét szedtem de meg is csináltam valamit :super:
Mindenkinek köszönöm szépen előre is a segítségét!További szép napot!
UI:Csatolok egy képet a kapcsolóról!A kapcsoló megoldást talált még pediglen Mekmuki tanyatársunk jóvoltából,aki volt olyan szíves és küld számomra egy donort!Köszönet neki érte és mindenki másnak is a tanácsokért és a javítási ötletekért!Nem akarok kis telhetetlennek tűnni,úgy hogy a téma megoldva :bow:
Üdv:morfeus
