BOSS GT580 SM
4.9 MB
Looking for similar boss manual?
BOSS GT580 SM service manual (1st page)
Preview of BOSS GT580 SM [1st page]
BOSS GT580 SM service manual (2nd page)
Preview of BOSS GT580 SM [2nd page]
    BOSS GT-580 GT580 GT 580
Help Kenwood
Hello, I am in a repair KENWOOD KRF-X9995D. Let me know if anyone is aware of how to reset the processor. That is about a year ago I had the same problem with another amp of the same model! So this is the second unit can not repair! The main flaw is that the accumulation of around 1F 5.5V had spilled acid. was also in the same thing happened! ie it shows mute, but going into test mode, (having pressed the key "INPUT SELECTOR DOWN" and "POWER", the analog input works (but only in TEST). Any help? Thank you
Request for Firmware or Help – Kenwood M-9000 SS stuck on "Waiting for PC Wizard"
Hello,
I recently purchased a used Kenwood M-9000 SS micro Hi-Fi system, but unfortunately, the unit is not functioning correctly. When I power it on, the display is stuck on the message "Waiting for PC Wizard", and the device becomes completely unresponsive – it does not react to any buttons or remote control inputs.
From my research, it seems that this issue may be caused by a missing or corrupted firmware, particularly related to the Sunplus SPHE8202 chipset used inside the device.
I have been trying to locate the correct firmware file (possibly DVDROM.BIN) that matches the hardware (the board ID may be BD305890BB9B50), but so far, I have had no luck finding a working download source.
Could someone please help me with:
  • The correct firmware file for this model
  • Instructions or guidance on how to recover the system using a USB flash drive
  • Any experience with solving this "Waiting for PC Wizard" message on similar Sunplus-based systems
Any help or direction would be greatly appreciated!
Thank you in advance.
Best regards,
Dejan Todorović
Tesla B4 orsós magnó megy de nincs hangja
Tisztelt Szakértők!
Vettem egy Tesla B4 orsós magnóm, mechanikailag jól megy de nincs hangja, illetve a hangszoróból nagyon nagyon gyengén jön az érthető szöveg ami a szalagon van ha 1cm ről hallgatom a hangszorót. Másik magnón kipróbáltam és jól szól ez a szalag.
Külső hangszórón se jó, tehát hangszoró hibája nem lehet.
Ha a magnó erősítőre van kötve akkor sincs hang, de egy másik B4  erősítőre kötve is jó.
Ez azt jelenti, hogy nem a végfok a rossz?
Tudna valaki segíteni hogy ilyenkor az előerősítő fokozatban lehet a hiba ha a magnő erősítő csatlakozóján sincs már jel?
Kondenzátor szakadás?
Ki lehet mérni melyik alkatrész a rossz( kondi vagy tranzisztor)?
Vagy tápfeszültéget illetve feszültségszinteket kéne mérjek a tranzisztorokon?
Megköszönném ha valaki tudna konkrét tanácsot adni (Mit mérjek multiméterrel) vagy esetleg elvállalná a javítását.
        Köszönöm
Marantz PM-350 előerősítő hiba (Megoldva)
Sziasztok. A címben szereplő erősítővel van egy kis gondom és segítséget kérnék tölletek. Két ellenállás megégett benne és nem tudom az értéküket. Rajzom van az erősítőhöz de sajnos nem lehet leolvasni róla az értéket. R761 és R762 ellenállásokról van szó gyanitom hogy egyformák. A másik kérdésem az lenne hogy C4558C ic-t mivel tudnám kiváltani. Köszönöm
