Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
Sziasztok! Most próbáltam ki, hogy mi gond van vele. A deck2 fele rendesen működik, de a Deck1 fele, az egyik irányba jól játszik le, de a másik irányba már nem. Bekapcsolva megforgatja a kazettát, és kikapcsol, és a kijelzőn a F03 hiba kód jelenik meg. Kiadatva a kazettát megint ugyan így csinálja. Az lenne a kérdésem hogy ez a hiba kód mire utal?
Üdv. Mindenkinek!
Van egy Wega System 500 A10-es erősítő nálam (áramkörileg hasonlít a V3840-esre), amely 15-20 perc probléma mentes működés után lassan el kezd torzan szólni és halkulni, majd a végén csak alig hallhatóan szól. Az elhalkulás idején a torz hang lehalkítással megszűnik. Amint kikapcsolom, azonnal kb. 2 mp-re visszatér a hang és rendesen működik, nyilván míg a 2×10.000 mikros szűrőkondi győzi energiával. Visszakapcsolva már rövidebb idő is elég a torz működésre és az elhalkulásra. A probléma mindkét csatornán jelentkezik. Gondolom, hogy tápfesz hiba lehet, bár a tápfeszt mértem és a +/- 40 V a szűrőkondenzátoron mérve folyamatosan fennáll, még az elhalkulás és a halk működés alatt is. Nem egy mai darab, talán az elko száradt ki. Egy dual-c Nichicon kondi. Érdeklődöm, találkozott-e már valaki ilyen hibával? A segítséget előre is megkösznöm.
Üdvözlet Mindenkinek!
A mellékelt képen egy Panasonic FW18 kétkazettás rádió-magnó törött rádióskála helyzetjelző fogasléce látható. Eltört, mert öreg és rideg, a műanyag nem hagyja magát megragasztani. Megoldás lenne, ha csak a fogasléc részét pótolnám, de ilyen kis méretű / 3x1,5 mm / fogaslécet égen-földön nem találok. Abban kérném a segítségetek, hogy hol lehet ilyen kisméretű fogaslécet beszerezni, vagy milyen más megoldással tudnám a problémát megoldani.
Megoldás:
TonyStark ötlete alapján megfelelő méretű kábelkötözőböl a két szél levágásával csináltam egy, az eredetivel megegyező méretű fogaslécet, és a skálajelzőre ragasztottam.
Kitűnően működik. Köszönöm a segítségeteket!
Laci
