A fenti készülék úgy került hozzám, hogy nem volt feszültség az USB-n. Egy kis SMD biztosíték szakadt meg, ezt cseréltem, működött rendesen, még DVD-t is néztem rajta. Megjárta a postát, és kibontáskor már nem ment a kijelző, és az érintőképernyő. Távirányítóval lehet kapcsolgatni, szól, működik. Rajza fent van, feszültségek megvannak, bár az előlapban belül nem tudtam mérni. Az ESD védődiódák nem zárlatosak, szkóppal nézve van valami kommunikáció. Előlap szalagkábele ép, előlap jól csatlakozik. Itt elakadtam.
Üdv: Jácint
Hello to everyone!
Thanks in advance if someone can help)
I have a problem with replacement of malfunctioned final amplifier at Cascade BE7944.
It is play sounds through front loudspeakers with distortion.
It is not a problem with wires (I have tested it them with ohmmeter) and loudspeakers (brand new).
I have replaced with Traffic pro and it worked fine.
Radioengineer has announced the verdict - problem with final amplifier and it is must be replaced, and preferably with service manual or schematic, which I do not have. And I did not allow him to unassemble my Becker just "for to watch how it is looks from inside")
The problem is following:
1. Do someone have and can share with me with service manual or schematic of Becker Cascade BE7944.
2. As far as I understand BE7944 is further development of schematic Audio 10 ECE Typ 6011 (or 4011), which service manual is available at Internet - can I use it as general background for BE7944?
3. At present time unfortunately there is no possibility to find original MLT TDA 7454, only CHN or unnamed versions. I do not want to install that, but according to datasheet for TDA 7454 it can be replaced with TDA 738 *. And TDA738 * can be raplaced with TDA 7560 or TDA 7850 (in my case TDA 7851 L). If it is possible to replace TDA 7454 with TDA 7851 L and with which modifications? And will I not lose the “Backer surround” function?
4. Any other suggestions? Please withought "sell this dinosaur"
I have written to Harman / Becker with this problem but still no answer ...
Thanks to all!
Jó Estét Mesterek !
Segítség !
Rajz nincs. Jó lenne ha valaki ismerné
Végfok : 2db TDA8954TH , halott. Kivéve.
Van benne egy ACT4060A amiről táplálkozik , illetve táplálkozott a BQ=W24 .
A BQ=W24 tönkre ment. A zárlat ez után van.
Míg élt mindkettő(ACT és BQ=W is melegedett nagyon..
Mi lenne ez a BQ=W , mivel helyettesíthető.? Én nem találtam.
Köszönném ha segítene valaki.
A kapcsoló tranzisztor nem zárlatos az előlap mögött. Még bogarászom, hogy mi kapcsolja.
Van ötlet?
Üdv: Jácint
A 7805 pozícióban a tranzisztor zárlatos volt. Az előlap csatlakozója mellett a sarokban vannak a tranzisztorok.
