Hello,
Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape.
Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors?
On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me.
I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were?
The service manual is on site here.
Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read.
I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty.
Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2:
Bellarmine
üdv: csak tanulságul
A gyerek hozta, hogy CD állásban egy idő után, kb a felénél elmegy a hang
Érdekes, a számláló tovább megy
Letakarítottam az optikát, a szánt, megolajoztam a motorokat, ellenőriztem a szalagkábelt, tápot, a hiba maradt.
2,5 V-tal meghajtottam a motorokat, szépen mennek, de a szánmotor a felénél megakad
Néztem tanácstalanul, mint a kisközség
Jobban megnézve az optika páros fogasléce alsó tagján a fogak közé beakadt a letört utolsó fog egy kis darabja.
Csak nagyítóval vettem észre, mert elbújt a zsírban
Jobban eltolva a fogasléceket összeraktam, kifogástalanul működik
Egyébként SOH-AD5 optika van benne, 11 éves a készülék és még működik
Áttéve a helyére!
Sternum electronics PM102 aktív hangfal ( 2x100 watt van ráírva a dobozára) végfok IC elfüstölt, de olyan szerencsétlenül, hogy a felirata nem olvasható teljesen. TDA 72.... valami ilyesmi.
Ebben kérném segítségeteket.
Az a vicc, hogy egyszer már javítottam, de akkor nem írtam fel a típusát.
Köszönet a segítségért!
