CONDOR S11 CAR RADIO SCH
143.2 KB
Looking for similar condor manual?
    CONDOR S-11 RADIO S11 CAR 11
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
Marantz Pm-551 tip. erősítő nem működik, nem jelez, reagál semmire
Új vagyok még itt! Hobbiként "űzöm" az elektronikát, de javítottam, építettem már ezt-azt.
Hozzám került egy kis ékszerdoboz a 80 as évekből..Marantz PM 551 tip erősítő képében. Persze nem működik...jó lenne visszahozni. Bekapcsolás után néhány led egy másodpercre felvillan, kattan egy relé (gondolom koppanásgátló) aztán se kép, se hang, semmire nem reagál.
kutakodtam a neten, kapcsolási razot találtam,
Egy fórumon olvastam, hogy a típus lelke egy a sanyo által gyártott 4 bites mikroprocesszor, amit lehetetlen már beszerezni.
Nos, azért rámértem itt-ott . A tápfeszek megvannak, ill a proc 22 es lábán 1 khz hullám mutatkozik. ahogy a csúcssal megérintem ezt a lábat néha némelyik led, ledek kigyulladnak...kb eddig jutottam.
hogy tudnám behatárolni a hibát? ehez kérném a segítségeteket!
REFLEXION X250 autóerősítő kapcsolási rajz
Üdvözlet. Tisztelt Mesterek! Tovább keresem a REFLEXION X250 autó erősítő rajzát.( www. ulramedia.de) ez vagy gyártó vagy forgalmazó. Csak fizetőst találtam. Tisztelettel Öreg T.
KENWOOD KRF-V 5030 TÁVIRÁNYÍTÓ HIBA / MEGODLVA /
Kérdezni szeretnék ! A fenti készülék és a hozzátartozó DVD nem reagál a távirányítóra. A távirányító oszcilloszkóppal vizsgálva az infra led kimenő jelét infra vevővel rendesen küldi a jelcsomagot, a rezonátor 3,64 MHz a rajta mért freki gombnyomáskor - 3,61 Mhz. Mivel sem a hozzátartozó DVD lejátszót sem a Recievert nem működteti gondolom a távirányító lehet ludas. Ha van tapasztalatot szívesen várom segítségeteket. előre is Köszönöm!
