I've done the user Manual reset but it still turns off and standby red led flashes.I,need a service manual and some help to change ac detect fault code.Can anybody assist .
Sziasztok mindenkinek.
A cimben emlitett radios erositovel bibelodok. A vedelmi rele veletlenszeruen meghuz/elenged. Nem hiaba, a kimeneten a feszultseg ossze-vissza valtozik, es amikor 0v korul van, a rele meghuz, aztan 1-2mp mulva elenged. Rovidzarat sehol nem mertem, kinomban mar az smd tokozasu eloerositot is kicsereltem (BA15218), de semmi valtozas. A tapfeszek stabilak. Nem tudom elkepzelni, hogy mi okozhatja a kimeneten a feszultseg allando valtozasat. Ha van valakinek erre otlete, kerem ossza meg velem. Koszonom. Udv.
Hello everybody,
This receiver starts normally and has a nice blue display lighting on for 8 seconds. Suddenly you ear the main relay falling down and everything turns off and you get the red led flashing around the main power switch button. There is no special code with this continuous flashing rythm of the led. I have no diagram of the device and I have opened it and measured the voltage on pin 4 of the voltage regulator KIA78R05P1, which has a validating signal on his pin four.(2 is the output and 3 is frame (-)).this 5V(to-220)monolithic 7805 regulator is on the main PCB, close to the little transfo and ON/OFF relay...and is mounted without any heat dissipator(I was surprised of that fact!).the voltage between(4-3)is 1,88V dc and never climbs up during the starting sequence.
Can you help me to solve this problem?
Top, backboard, back, with HDMI processors to Denon Receiver AVR-4311 Network, offer 100% top condition. to different receiver, I can help from boards to television, I have some also for receivers Replace parts, some, nice day. I could not add the board as a file because it is larger and overcomes mbit, is above 3000kbit, thank you.
