I've done the user Manual reset but it still turns off and standby red led flashes.I,need a service manual and some help to change ac detect fault code.Can anybody assist .
Üdv mindenkinek!
Tárgybeli erősítő hálózati trafójában megszakadt a hőbizti. Tulaj tök hangerőn használta még el nem hallgatott.
Ez a trafó csak horror áron beszerezhető. A biztosíték meg úgy van beépítve, hogy nem lehet egyszerű módon javítást eszközölni, mert az alsó tekercsen helyezkedik el, nem hozzáférhető módon. Van valakinek tapasztalata, hogy hogyan lehetne a legegyszerűbben javítani?
Üdv, Elbandi.
Problem with Denon-Heos-AMP HS1
Cause:
After a factory reset attempt that fails, the following problems occur.
PS
The unit worked just before the factory reset!
Problem:
The device tries to update the firmware automatically (online), but it fails.
The device then flashes red continuously.
According to the service manual, the only option is to load a new factory firmware using a USB dongle.
After many hours of searching the web, I have not been able to find this firmware file.
The service manual refers to an SD (service disk).
The Denon service office does not sell or provide service application software.
I hope for further information/help to solve this problem
Regards Mogens
Hi to all. Unit arrived dead with no power. The problem is with switching power supply. I checked most of the parts, no faulty found. Unable to check PWM ICs. To determine which one has the problem, Service Manual is more than important and necessary. I would appreciate if someone of you can help me find it or send it to me.
Thanks in advance for your kind attention and help.
Regards from Greece,
John
