DYNACO ST-120 SZTEREO VEGFOK SM
10.4 MB
Looking for similar dynaco manual?
    DYNACO ST-120 VEGFOK ST120 SZTEREO ST 120
Dynacord Powermate 1000-2 mixer amp fault - Help needed
Hiya
I am repairing a Dynacord Powermate 1000-2 mixer/amp and have a question about DC blocking capacitors in the signal path.
I am getting a slowly dropping DC on the DISP1 node (output of I6AA op-amp) on switch-on.  This is causing the green "signal present" LED to come on on that channel which takes about 30 seconds to turn off.  It seems to be caused by a charge on C35A that dissipates slowly through R54A (1M Ohm).
It seems to me, it would have been better to put the C35A on the output of I5AA with a resistor to ground.  Is there a reason why this would not work.
I have checked all relevant components and power supplies and I cannot find any faults but I'm sure this is not normal behaviour.
Any help greatly appreciated.
PM1000 tone circuit
signal indicator
dynacord gigant v
Sziasztok! Szükségem lenne a dynacord gigant v kapcsolási rajzára Szereztem egy ilyen szép példányt, de hiányzik egy bemeneti, kimeneti panel a hátuljáról. Sajnos az adatbázisban csak a gigant 1 található, ami csöves, ez pedig MJ15003-MJ15004 komplementerrel megy. Előre is köszi
Dynacord cms1600-3 service manual
Hi, need help get service manual for Dynacord CMS1600-3 a very wanted audio mixer in India. I don't know why company does not publish schematic diagrams of the machines. Tried all web sites, could not find anything helpful. It has smps with microprocessor, available in the market but the software is not. Effect board is also costly. I will be very much thankful to get help. Thanks again.
Dynacord A 2002 torz, halk
 Egy Dynacord A 2002-es erősítőt hoztak be, mindkét csatorna halk, torz, az egyik jobban, a másik kevésbé. Sajnos rajz nincs hozzá, de a "vak tyúk is talál szemet" módszerrel azért próbálkoztam, és azt tapasztaltam, hogy az erősítő paneleken van egy csatlakozó, amire egy-egy árnyékolt vezeték jön. Ha ezt lebontom, szépen, tisztán szól mindkét végfok, és az eddigi kb. 10% helyett szinte maximálisan ki lehet vezérelni. Ezek az árny. vezetékek a fényképen látható, tollal mutatott, valami betonkemény anyaggal leragasztott valamibe csatlakoznak, amiket addig nem merek szétbontani, amíg nem tudom, mi az, és tényleg azok-e a hiba okozói. Ezek a hűtőbordára vannak ragasztva
Tudna valaki segíteni?
Köszönettel:
