Tiszteletem a Tanya lakóinak!
Meglehetősen kalandos úton került hozzám, egy Osram valami.
Csatolok, néhány képet, valaki talán felismeri.
![](/files/1-lap.jpg)
A barátom, a feliratok alapján, nem volt barátom.
Megtisztelő válaszaitokat előre is köszönöm:
exGelkás
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Elég egyedi a kérdés, de hátha belefutott már valaki a fenti vagy hasonló eszköz javításába.
Azzal került hozzám, hogy az egyik DVI bemenet nem megy.
Próbálgatva nem is lehetett forrásként kiválasztani a rossz bemenetet.
DVI bemeneti IC-re gyanakodtam, adatlap persze nincs az IC-hez.
Méregetve, összehasonlítva a mellette lévő másik ugyanilyen IC-vel, tápok szerintem rendben viszont a "rossz" lábain nincs értelmezhető jelalak.
Gondoltam kapott valamit az IC mert egyik ilyenben sincsen befele az IC felé semmilyen védelem.
Cserére lett ítélve, persze nem rendelhető itthon sehol, így maradt az e-bay.
Meg is érkezett, kicseréltem.
Most már ki tudom választani az eddigi rossz bemenetet, de "No signal"-t ír rá, és nem ad képet ezen a bemeneten.
Mérve kb. ugyanolyan jelalakok vannak a lábakon.
Rajzot égen-földön nem találok az eszközhöz.
Lehet tovább jutott a hiba csak hát rajz nélkül ez nehéz lesz...
Viszont egy érdekes jelenségre lettem figyelmes.
A jó bejáratra dugva a jelet egy Apple gép azonnal átvált 2 képernyős üzemmódba függetlenül attól, hogy az eszköz áram alatt van-e vagy sem.
A rossznak ítélt bejáratra dugva viszont nem akar beváltani ugyanilyen módba.
Keresgéltem a neten, de nem találtam rá utalást hogy kell ezt a módot elérni.
Egy dolgot tudtam erre elképzelni hogy a DVI csatlakozó 14-es lábán található +5V-ot visszavezetik a 16-osra a Hot Plug detectre, a panelon viszont mindkét DVI csatlakozón ugyanolyan értékeket mértem, úgyhogy nem értem.
Valakinél nem lapul a fiókban egy service manual ehhez a készülékhez?
Köszi,
Krisztián
Kaptam egy Akai Orsós magnót aminek a hibája lejátszáskor egyik oldala nem szól viszont felvételnél felveszi mindkét oldalt csak a lejátszás nem üzemel valakinek valami tippje van ezzel kapcsolatban gondolom itt többen javítottak már ilyet ....
