EKCO B74 BATTERY RECEIVER 1933-45 SM
692.7 KB
Looking for similar ekco manual?
EKCO B74 BATTERY RECEIVER 1933-45 SM service manual (1st page)
Preview of EKCO B74 BATTERY RECEIVER 1933-45 SM [1st page]
EKCO B74 BATTERY RECEIVER 1933-45 SM service manual (2nd page)
Preview of EKCO B74 BATTERY RECEIVER 1933-45 SM [2nd page]
    EKCO B-74 RECEIVER B74 BATTERY 193345 74 1933 45 1933-45
Pioneer MVH-170UI Usb-s autórádió nincs hang
Tisztelt fórumozók! A fenti autórádióval volna problémám, éspedig az, hogy bekapcsol, tökéletesen kijelez mindent, de hangja nincsen. A végfok jó, a PM9013 vol Ic bemenetén van jel, a kimenetén semmi.Megköszönném, ha valaki segítene! https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0CAcQjRxqFQoTCITqgv3eqsgCFUQ6FAodzS0EQQ&url=http%3A%2F%2Fwww.pioneer.eu%2Fuk%2Fproducts%2F25%2F121%2F61%2FMVH-170UI%2Fpage.html&psig=AFQjCNFpmPq843T6UWjtH-FDZmm93n4QBw&ust=1444114247062821
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
SONY HCD-RG11 széles szalagkábel keresés (19pin)
sziasztok! Hozzámkerült egy SONY HCD-RG11 amiben nem ment a cd, elvitték valakihez aki szétkapta , a tetejét úgy leszedte hogy a (19 érintkezős) szalagkábelelfelejtettem a méreteket leírni a hossza: 190mm szélessége 25mm (széles ami a proci laphoz volt kapcsolva elszakadt,ezt kellne pótolni beszerzési forrást keresek, vagy ha van valakinek persze nem ingyen. előre is köszi attila senkinek?
Videoton ra4101s komplett kapcsolási rajz ua758 stereo dekoderrel
Hozzám került a fent említett rádió készülék. A hibái nagy részét megjavítottam. Fontos különbség: ua758 stereó dekóder van benne. A belső kábelezése és a kapcsolása a fellelhető rajzoktól eltérő. A jobb oldal csak URH-n nem szól. Kérésem: Ha valakinek megvan ennek a változatnak a kapcsolási rajza kérem tegye hozzáférhetővé (nekem is) Elnézést kérek a Moderátoroktól hogy ebbe a fórumba írom, de a problééma igen speciális, az alap verziót (tranzisztoros dekóderrel), itt is megtaláltam. Köszönöm ! Péter.
