GRUNDIG R400 CC420 CC430 SM
12.2 MB
    GRUNDIG R-400 R400 CC420 CC430 400 CC 420 430
GRUNDIG satellit 208 transistor 6000
Trying to troubleshoot a issue with this radio and there are some SM / schematics on some websites,
but they are slightly different than this one.
Would anyone know a place to look where there are some Grundig people familiar with the products?
Grundig YB-P 2000 not working on AM bands
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Grundig M49
Sziasztok. Keresek Grundig M49-DPL hifi toronyba bontott vagy új készenléti trafót.Üdv.Solyom
Grundig aktiv box aktív hangfal automatikus bekapcsolásának átalakítása?
Sziasztok! Van egy kis gondom Grundig aktiv box 50 típusú hangfalaimmal. A hangfal végfokai csak egy bizonyos szintű bemenőjelre kapcsolnak be, hogy feleslegesen ne fogyasszanak áramot, jel nélkül kb. 5 perc után kikapcsolnak (a két doboz meglehetősen jó együtt futással teszi ezt). Ez a szint normál körülmények között elegendően alacsony, de esténként én már csak nagyon halkan szeretek zenét hallgatni, ilyenkor rendszerint ki szoktak kapcsolni a hangfalak, ilyenkor állandóan játszani kell a hangerőszabályzással, mivel a bekapcsolási küszöbszint nagyobb, mint a benntartási szint. Ezt a problémát szeretném megoldani, mégpedig a bekapcsoló áramkör érzékenységének növelésével. Kapcsolási rajz vonatkozó részlete A fokozat bemenete a hangfal bemenő buffere (~egységnyi erősítés) után van közvetlenül, 9,5V DC előfeszítést kap. A probléma már régóta foglalkoztat és régen volt egy kósza ötletem, hogy a D2,D3 diódát kicserélem germániumra és a kisebb nyitófeszültség majd mindent megold, de ettől semmi nem lett jobb, csak rosszabb, mert a germánium dióda nagyobb visszárama miatt az egyik hangfal igen sűrűn kezdett kikapcsolgatni (és a bekapcsolási szint egy fikarcnyit sem csökkent) Némi tanulmányozás után most arra jutottam, hogy valószínűleg az R32 (1MOhm) ellenállás csökkentésével lehetne a problémát orvosolni (esetleg R17, R18 változtatásával?), de megerősítést (vagy ellenérvet, illetve tanácsot) kérek, mert az áramkör szerelése amúgy elég nagy meló (nehéz hozzáférni), szóval ha még egyszer kiveszem, akkor szeretnék már biztosra menni.
