HARMAN-KARDON MODEL TA-230 SM
11.0 MB
Looking for similar harman manual?
HARMAN-KARDON MODEL TA-230 SM service manual (1st page)
Preview of HARMAN-KARDON MODEL TA-230 SM [1st page]
HARMAN-KARDON MODEL TA-230 SM service manual (2nd page)
Preview of HARMAN-KARDON MODEL TA-230 SM [2nd page]
    MODEL TA-230 TA230 TA 230 HARMAN KARDON
May be useful - Harman Kardon information
For your information to repair Harman KArdon HD710 Player uses a KSS210B Pickup (as spare, original unknown) can be changed without any other servicing Harman Kardon Receivers; Series AVR 2000,3000... "Looses memory issue"- gold cap at the front pcb defective. May be changed to a 1µ cap but you have to solder 3 other elko´s to the other side. Keeps memory for a longer time. "Hum noise for the first 5min, warm up" - right lower side at the main pcb: elko 7800µ dead- you can see it at the "cap of it". Replace both (7800µ and 2200µ) to new versions above 25V. "Fuse burnt voltage selection; no green led´s flash, no sound"- cap 2200µ make a short circuit (next to 7800µ). Change these elkos! If you want to make it better... change the 7x 10µ caps for the regulators too. Resolder all points there. "volume changes self to max. or min." change the two resistors at the front pcb close to the volume encounter. be sure that there are both sides 5V! "everything is functional but no sound; but sound from the 6.1ch in" TC9273N-07 is dead (shorted). Have a look at the two caps and the security resistors beneath this chip! My be dead too. Replace this chip only by the -007 version. others will not function. Be careful with the bigger stripe cable! the contact lines are loosen from the plastics. You can help yourself with a "second glue" under these contacts. So i hope i can help you... cheers SG.
Harman Kardon - HK6650R erősitő koppanásgátló
Tisztelt Kollégák!
a cimben szereplő erősitővel kapcsolatban lenne kérdésem (a kapcsolási rajza fenn van a Tanyán):
az erősitő be- és kikapcsolásakor a hangszóróban egy a "koppnásnak" megfelelő hang hallatszik.
A berendezésben nincs beépitve hagyományos "relés" koppanásgátló, de van egy áramkör, amely a bekapcsoláskor
illetve hiba esetén (pl. hangszóró rövidzár) kb.10[s]-ig némitja a végfok bemenetet, valamint kikapcsolva tartja
a meghajtó tranzisztorokat is.
Mivel ez a  jelenség mindkét végfokon egyformán tapasztalható arra gondoltam, hogy ez az erősitő konstrukciójából
adódik.
Sajnos másik ilyen tipusú berendezést nem volt alkalmam kipróbálni - megerősitést szeretnék kérni a jelenségről olyantól akinek van ilyen
erősitője- vagy hasonló (pl. HK PM 655, PM 6500), illetve találkozott már ezzel a problémával.
Köszönöm,
                   Tamás
Harman Kardon AVR200 volume -71 ír ki ha a hangerő encodert tekergetem
Sziasztok! Tudnátok segíteni? Lenne ez a 5 csatornás rádió erősítő. Hang nem jön ki rajta, de ha a hangerő encoderhez nyúlok annyit ír ki: VOLUME-71, a -71 villog . Más gombra reagál, tehát átvált a bemenetek között, hangolható, stb. Mi lehet ez? Köszi
Harman/Kardon AVR65 RDS - Sudden Sound increase
Hello! Harman Kardon Receiver /amplifier AVR 65/RDS ! increases the Volume by it self some times (Suddenly) pse. advise .. Works Well otherwise! Best..Regards Rune..Sweden
