HEROFON 340U 1941 SCH
Type: (PNG)
79.1 KB
Looking for similar herofon manual?
    HEROFON 340U 1941 340
Denon AVR-1803 (6+1 erősítő) csak stby led világít
Power kapcsolóval bekapcsolva kivilágít a piros stby led, majd fél másodperc múlva kapcsol 2db relé, nagy trafót kapcsolja az egyik a másik valószínű a hangszórót kapcsolja.
Kijelzőn semmi, de a kijelző fűtése az megvan, 78R05-ön megjön az 5V, de nem reagál semmi gombra.
Ha factory resetet megnyomom (2gomb+power) akkor 10% fényerővel kivilágít és ugymarad az összes szegmens de továbbra se működik semmi.
Távirányító nincs hozzá, előéletét nem tudom mert Németországból kukázták..
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
PPO P-006U többfunkciós rádió trafó hiba (megoldva)
Ebbe a rádióba kellene, hátha van valakinek. Nekem van egy HQ  panel trafóm bele is férne de 6V-os. Túlélné a rádió?, mert a rádió  DC-je 4.5V
http://opttorg-vostok.ru/index.php?route=product/product&product_id=330
Kész és átraktam a javítások közé. Ilyen trafó oldotta meg a baját.
https://www.hqelektronika.hu/tapegysegek-transzformatorok/transzformatorok-ferritek/halozati-transzformator/nyak-trafok/trafo6v1-8a-trafo-230vac-6vac-0-3a-1-8va
Sony str-gx211 rádióerősítő, se kép, se hang...
Hi!
Lenne ez a ketyere. Az egyik csatorna egyik végtanyója k.o. volt, kiszedtem, most üres a helye.
Felálltak a tápok, de semmi életjel. A 5V és a -24V megvan az előlapon.
Kellene mennie a kijelzésnek ha eltolódik a munkapont az egyik végen?
Kösz
