HYUNDAI H-HT5111N BIN
VIDEO-DVD - EPROM
681.2 KB
EPROM
Looking for similar hyundai manual?
    HYUNDAI HHT-5111N BIN HHT5111N HHT 5111 HT5111N H-HT5111N
Esquema da fonte do VCR Panasonic NV-260 OBS: (Não é o NV-SD 260)
Friends !
Preciso do equema da fonte do VCR Panasonic NV 260, porem não serve o NV-SD 260 pois a fonte que ele utiliza é com transformador e não chaveada.
NEC DS8000U getting an error trying to upload to ElektroTanya
I have an owner's manual for a NEC DS8000U VCR which I bought simply to get the model number of the remote control.  I was hoping to upload scans of it to help others as it does not seem to be available for download anywhere.  However I cannot upload to ET, when I do so I get the error message
Upload Failed!
This filename already exists.
If you want to upload anyway try to rename the file and upload again.
File was named "NEC DS8000U Owners Manual.pdf"
What am I doing wrong here?  I've tried renaming the file as well, and searching ET for "DS8000U" doesn't give any results.
VCR Panasonic NV-260 (Esquema eletronico da fonte)
Hello everyone, thank you for participating in this forum. I need the electronic layout of the Panasonic NV-260  video source. I have already researched several lines without success. Does anyone have this electronic schema?
panasonic nv-sd442 fejdob
Sziasztok!Bontott fejdobot keresnék, négy fejes felső motoros.Melyik tipusokból lenne pont jó a magnómba.Köszi a segitséget.Joska.
