IC TL1451ACNSR INVERTER SCH.
OTHER - SERVICE MANUAL
122.2 KB
Looking for similar ic manual?
    IC SCH. TL 1451 ACNSR
Yamaha KX-250 Cassettedeck output tick noise problem (electronic not mechanical)
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
Microstar gpsre IGO 8
Helló! Az egyik barátom kapott egy ilyen készüléket. IGO 8-at akart rá tenni, de nem igazán ment neki. Van ennek vmilyen különleges megoldása? Üdv.: Ízirájder "FONTOS! Olyan fórum téma nevet válassz, ami beszédes, minél pontosabban illeszkedik arra, amivel kapcsolatban írsz. Egy lehetséges jó elnevezés pl: ORION LCD PT26S chassis 17MB12-2, a tápja nem indul Az nem elég, hogy pl: "LG LCD-TV" vagy "HP laptop" és hasonlóak. Illetve érdektelen, nem releváns információt se tartalmazzon a cím! A helytelenül elnevezett topik felfüggesztésre, majd 48 óra után törlésre kerül! Felfüggesztett állapotban nem tudnak mások addig hozzászólni, amíg ki nem javítod a címet. A hibás cím utólagos javítása (48 órán belül) a "Szerkesztés" fülre kattintva végezhető el." Igazad van, jogos a pont.
VICTOFON hallókészülék gond
Szervusztok ! Nagymamám hallókészülékével támadt egy kis gond. Nevezetesen az, hogy folyamatosan sípol, gerjed. Még új elemmel is. A kis potméter ami a hangerőt hivatott állítani, gyakorlatilag már a leg csekélyebb mozdításra is gerjedésre bírja a készüléket. Található továbbá még 2 mikro trimmer is a készüléken. Ezeknek a funkciójára lennék kíváncsi, ha tudná valaki. (mic. gain talán ? ) Ha esetleg egy kapcsrajz is lenne, az is sokat segítene. Köszönöm !
Police 30000 KV akkumulátor?
Hozzám került ez a POLICE 30000 KV kis lámpa, akku és töltő nélkül.
Egy szokásos 2-3 Ah-ás  Lithium akkut bele tettem (sokkal vastagabb ennél ami bele való lehet, de hosszra OK). Mivel ez egy eléggé nagy fényerejűnek van leírva, (és láttam ennél nagyobb fényerejű kis lámpát is)  gondolom, hogy ez a 4 Volt kevés neki. Ami még feltűnt, hogy addig ég, amíg nyomom a gombot, egyszer teljes fényerővel, máskor meg szaggatva.
Én nem találtam információt, hogy milyen akkumulátor a bele való. Tud valaki segíteni? Milyen, hány Voltos, és mekkora Ah-ás akku való bele?
Köszönöm: formasu
