A hqnál kapható STK4036II megbízható IC?
Esetleg hasonló árú beszerzési forrás?
Hello, I got a problem with my Sony Receiver STR-DE 225.
There´s a sudden interruption of Audio in non defined intervalls - may be once ore 6 times during appr. 5hrs operation.
Interruption does not depend on Volume. Connection cables and speakers I´ve checked.
There´s a loud crack in both speakers, display shows for short time "PROTECTION".
After switching off and on again, everything operates normal until next interruption.
I removed from the inside of the receiver a lot of dust with a vacuum cleaner, but this didn´t help.
Unfortunately Sony has no documents for this device, as it is To "old" (1996), or could give me a hint,
in what cases "PROTECTION" might appear.
Is there anyone to give me a clue? Thanks
Hi,
I am working on a Luxman L100 belonging to a friend. I noticed the following problems.
a) It takes about 12 to 15 secs for the relay to turn ON.
b) The relay does turn ON but both the "winker" bulb and "ON" bulb do not light
(both the bulbs are OK)
c) The "touch MUTE" is not working.
d) When switching on the 10Hz low cut filter, the relay cuts off and does not come ON until the switch is set in the centre(bypass). Can someone familiar with this amp, please help me out
Thanks
Carlos
A helytelenül elnevezett topik felfüggesztésre [F], majd 48 óra után törlésre kerül! Felfüggesztett állapotban nem tudnak mások addig hozzászólni, amíg ki nem javítod a címet.
"IMPORTANT! Select a forum topic name that is descriptive, more precisely matched to which you're writing about. A possible good name
eg, ORION LCD-2 17MB12 PT26S chassis, the power supply for will not start
It is not enough, for example: "LG LCD TV" or "HP laptop" and the like. And do not include irrelevant information not relevant to the title!
The incorrectly named topic suspended [F] and will be deleted after 48 hours! Suspended while others are not able to speak until you correct the title.
Subsequent repair of defective title (within 48 hours) by clicking the 'Edit' tab to be done."
Szeretnék segítséget kérni, hogy pontosan mi a menete a képen látható AVA Model 2A végfok beállításának, a végfok csövek 2-2 db párhuzamosan push pullba kapcsolt EL84, a katód áram a gyártó ajánlása szerint 30 mA. Gondolom az egyik potival a negatív elő feszültség nagyságát állítom a másikkal pedig a két oldal szimetriáját lehet beállítani. Ez a 30mA csövenként vagy oldalanként értendő. Illetve mi a beállítás pontos menete ?
Előre is köszönöm a válaszokat.
Antal
