JVC KW-V11E,KW-V11EE,KW-V11EU,KW-V11J,KW-V11JW,KW-V11U,KW-V11UI,KW-V215DBTE,KW-V21BTA,KW-V21BTE,KW-V21BTEE,KW-V21BTEU,KW-V21BTJ,KW-V21BTJW,KW-V21BTU,KW-V21BTUI EXPLODED PARTS LIST
Size 362.4 KB
Page 22
Category CAR-AUDIO SERVICE MANUAL
If you get stuck in repairing a defective appliance download this repair information for help. See below. Good luck to the repair!
Preview of JVC KW-V11E,KW-V11EE,KW-V11EU,KW-V11J,KW-V11JW,KW-V11U,KW-V11UI,KW-V215DBTE,KW-V21BTA,KW-V21BTE,KW-V21BTEE,KW-V21BTEU,KW-V21BTJ,KW-V21BTJW,KW-V21BTU,KW-V21BTUI EXPLODED PARTS LIST [1st page] Click on the link for free download!
Preview of JVC KW-V11E,KW-V11EE,KW-V11EU,KW-V11J,KW-V11JW,KW-V11U,KW-V11UI,KW-V215DBTE,KW-V21BTA,KW-V21BTE,KW-V21BTEE,KW-V21BTEU,KW-V21BTJ,KW-V21BTJW,KW-V21BTU,KW-V21BTUI EXPLODED PARTS LIST [2nd page] Click on the link for free download!
If you have any question about repairing write your question to the Message board. For this no need registration.
If the site has helped you and you also want to help others, please Upload a manual, circuit diagram or eeprom that is not yet available on the site. Have a nice Day!
Warning! If you are not familiar with electronics, do not attempt to repair! You could suffer a fatal electrical shock! Instead, contact your nearest service center!
Note! To open downloaded files you need acrobat reader or similar pdf reader program. In addition,
some files are archived, so you need WinZip or WinRar to open that files. Also some files are djvu so you need djvu viewer to open them.
Üdv Mindenkinek.
Adott a tárgyban szereplő JVC KS-ES100 equalizer. Nincs kijelzés. Ez csöves kijelzőbel rendelkezik. Ennek a tápfeszét egy kis dobozba épített inverter szolgáltja illetve szolgáltatná. Volt ebben két elkó ami kifolyt. A penel alaposan lemostam az elkókat cseréltem. Az inverter beindul úgy 15 mp-ig műküdik majd leáll. Amíg múködik addig az előállított feszek jók. -25 v és csőnek a fűtése. De a kijelzés továbbra sem múködik. A kérdésem az hogy erről a készülkről van-e valakinek egy rajza. Ilyet a neten nem találtam. Itt a tanyán csak KS-ES 200 van de az teljesen más. Ha esetleg valaki ilyet javított és sikerült megoldani az kérem ossza meg velem Köszönom.
Sziasztok. Segítséget szeretnék kérni a címben szereplő készülék javításához.
A hiba az hogy a kijelző nem működik és a gombokra nem reagál. Feszültség alá helyezve a gombok világítanak és egyet csipog.
Van benne egy cd lemez amit elkezd beolvasni közben ismét csipog hármat. A beolvasás végén, mikor leáll a lemez forgatása megint csipog hármat és kikapcsol.
Visszakapcsolni nem lehet. Ha elveszem a feszültséget, és vissza adom ugyanezt csinálja.
IC801-el jelölt szabályzó feszültségeit mértem, ezek rendben vannak.
Hol keressem tovább a hibát? Köszönöm.
Hello my seniors
i have JVC KD-AV7001amplifier reciver how can i test it with out its monitor or controller is there any possibility tips and tricks you can show me please ?..
great respect ...
Sziasztok! A címben említett autórádió szól, ha ráakasztom 2 8ohmos hangfalra, 1db zeneszám után nem állja a kezem a hűtőbordát. 4ohmmal ugyan ez. Namármost itt ugrik a majom a vízbe: ha mem teszek rá hangszórót, csak a jelet viszem másik erősítőnek, ahogy kimaxolom a hangerőt kiugrál a táp ampermérője 3A-ig. Ha leveszem a hangerőt 1A-t kér. Létezhet olyan, hogy bár gyönyörű szép tisztán szól a végfok, mégis valami baja van? Egyébként HA 13158A IC van benne.
If you want to join us and get repairing help please sign in or sign up by completing a simple electrical test or write your question to the Message board without registration. You can write in English language into the forum (not only in Hungarian)!
