JVC RX-5042S SM FULL
3.9 MB
JVC RX-5042S SM FULL service manual (1st page)
Preview of JVC RX-5042S SM FULL [1st page]
JVC RX-5042S SM FULL service manual (2nd page)
Preview of JVC RX-5042S SM FULL [2nd page]
    JVC RX-5042S FULL RX5042S RX 5042 5042S
Turntable Victor/JVC TT-71
Given:
Victor TT-71, neon lamp does not light, speed is lower than normal.  This is subsequent some short circuit the owner does inside the device.  No further details.
I found out the VICTOR QL7 have the same motor driver amd I downloaded the service manual that I attached here in case this manual is not already uploaded.
Looking at the diagrams I found out that at TP3 (same with pin5 of IC803) instead if that rectangular signal, I have nothing but 5VDC and a negative or positive short spike whenever I'm starting or stopping the motor and
Under the circumstances I suspect IC803 is defective.  The bad thing, IC803 is NPC SC8043.  Also I wonder if the crystal is fine (except that I wonder what can be wrong with a crystal after some short circuit).
Does anybody have any more suggestion?
Also, where can NPC SC4043 be sourced?  Also, a crystal 9.054MHz?
Thanks in advance,
Corneliu
Receptor JVC RX 1010v fallo en placa E 12057-005 Transistores IC611 IC612 defectuosos, imposible leer valor
Se trata  de fallo localizado en placa E1205777-005 los elementos c1041 c1042 c1043 c1044 de valor 47 mF 25V los cuatro en mal estado y IC 612 e IC611 corroidos por acido de los condensadores electroliticos, me es imposible leer los valores de los mismos ; Y en el diagrama  no figura la placa del receptor RX- 1010  JVC. Codigo placa según diagrama
E 12057-005
Alguien podria por favor ayudar a localizar los valores de estos transistores.
JVC-th-a25 Házimozi "protection" kijelzéssel lekapcsol. (Már nem kapcsol le - Mukogy van).
Üdv mindenkinek. Nálam landolt a fent nevezett házimozi erősítő.Annyi a nyígja,hogy ha be akarom kapcsolni (stand-by -ból) akkor csak annyit csinál,hogy kiírja a kijelzőre,hogy "PROTECTION".Van a tápkörben a hálózati részen 2db relé.Az egyáramkörös kapcsol,a 2 áramkörös nem.Tehát bekapcs,egyet kattan a relé,közben kiírja,hogy "PROTECTION" ,majd visszamegy készenlétbe. A kapcsrajzot innen töltöttem le.JVC-ék kicsit vicces handgulatban voltak,mert polaritásilag vannak azért hibák a rajzba.Pl.a relékkel párhuzamosan kötött diódák fordítva vannak a rajzon,zener dióda fordítva.Csak a rend kedvéért említettem meg. Van a letöltött anyagban hibakeresési folyamatábra is,van is benne szó a "PROTECTION" hibáról.Csak annyi a baj az egésszel,hogy ott feszültségeket kellene mérni.Azt meg nem tudok,mert ez kapásból lekapcsol,ugye.Végignéztem a végfoktranyókat zárlatot nem találtam,értékük gyakorlatilag megegyezik csatornánként. Aki tud legyen szíves segítsen,hogy merre induljak el. Köszönöm.
Kvarc azonosítása: K ÐS5F (JVC KD-G401 autórádióból) Azonosítva!
Kedves kollégák! Egy autórádióban találkoztam ezzel a kvarccal, de semmi infót nem lelek róla. Pici, hengeres tokozása van, a jelölésben a D betű szára át van húzva. A kapcsolási rajzon nincs feltüntetve frekvencia, a típus is csak egy JVC azonsító szám. ( QAX0401-001 ) Minden infót köszönök! Üdv: Jácint
