KAPSCH WEEKEND5 TUBES RADIO SCH
Type: (JPG)
228.2 KB
Looking for similar kapsch manual?
    KAPSCH WEEKEND-5 RADIO WEEKEND5 TUBES WEEKEND
CROWN PS-K150 magnós rádió
Sziasztok. A fenti kétkazettás rádió-magnót javítom.Az a hibája, hogy a kazettát min. kétszeres sebességgel játssza le. Mi lehet a kínja neki? A motorra 4 derót megy. Olyan mintha nagy sebességű másolásnál(hi speed dubbing) hallgatnám, de ennek a kapcsolója jó és ki/be kapcsolva is ugyanilyen gyors.Ha valakinek van rajza róla légyszi küldje el. Köszi.
Trio-Kenwood: KR-3010 [Radio] S.N.962845 / Does not work, the final floor and prefinal floor defect with many burned component/
I greet you! I would need the scheme of this "vintage" amplifier that needs to be "restored". The problem is that in the prefinal and final floor I have many "fried" resistors well, their value cannot be identified.I replaced the defective transistors: 2SC1509, 2SA777,2SB690 and 2SD 796 (each 2 pcs.) and the electrolytic capacitors adjacent to them. I could not go further because of the carbonized resistors that I do not know their value (I can only guess that they are values small, in the order of ohms). The schematic diagram I downloaded, from the address received by the kindness of a colleague is not complete - it is a single page (missing Q29-Q30-Q31-Q3 and resistors R115-R116-R117-R118 which are completely carbonized, at other resistors I could see their value).Thanks in advance!
Finally, I found the missing part
If stuck in the repair and you ask questions, please do it as follows: - Details: Give the exact model number of your device and the chassis ID (if there is). - If possible, please attach pictures of the appliance. - Anamnesis: Write down the exact symptom. If hard to describe the symptom, it is difficult to verbally defined clearly, attach pictures or sound of the phenomenon! - Tell what was you have done so far: search contact error, which parts has examined or changed yet, etc... The incorrectly named topic suspended and will be deleted after 48 hours! Suspended state while others are not able to comment until you correct the address. Subsequent repair of the defective title (within 48 hours) by clicking on the "Edit" tab can be carried out.
LG BH6420 házimozi kikapcsol / nincs hang
Az házimozi bekapcsol, lemezeket olvas, kép és hang van HDMI-n. Hangfal kimeneteken nincs és kb 1 perc után kikapcsol Goodbye felirattal.
Ha lehúzoma mainboradról a AMP board-ot akkor nem kapcsol ki. Tápban cseréltem az elkókat és a Q902 FET-et.
Minden fesz megvan kivéve a 36V(PVDD).
Valakinek tippje, hogy merre menjek tovább?
roadstar cd-354mp/fm
Üdv! Aki tud kérem segitsen! A témában emlitett tipusu lejatszóhoz kellene nekem egy rajz.Van itt egy service manuals de azon nincs rajta amire nekem szükségem van. Ami után nyomozok az egy olyan rajz lenne ami megmutatja hogy a rádió kimenetén a 2X10 db tű közül melyiknek mi a szerepe!A gyári kábel elveszett és lenne nekem pici saruim csak nemtom h mit melyik helyre kössek!Aki ebben tud nekem segiteni örök hálám! üdv
