Hi Techs
Has someone a service manual of this audio set from Skytec type ST100
Regards
Adrie Neyenhuys
"Diagram, service manual page, to the right of the "Request / WANTED" box "CLICK HERE" button for request through!"
Hi All,
Does anyone have any experience of working on this radio, its the small Grundig with a leather case designed by F.A. Porsche.
I have recently repaired one with corroded battery contacts which had obviously not worked for many years.
Its now working perfectly on FM, but MW and SW1 and SW2 have no reception, just noise.
If I leave the radio connected to a 5v power supply for many hours it does actually get some reception on AM, but its not consistent. I'm thinking the fault is somewhere in the 'front end', oscillator stage perhaps.
I have checked the AM coils and wave selector switch are OK and everything is visually in excellent condition.
Reading various reviews on this radio confirms they were sold very cheaply in the USA and many customers have complained there is little or no sensitivity on AM, whilst others say it works perfectly. This makes me wonder if there is a common fault on these which someone may know, before I start with my test equipment to try to find the problem...
Any advice would be much appreciated!
Hi,
I am looking for the service manual "Cambridge Audio Stream Magic6 v1" or the schematic of the power supply.
Thanks in advance
Phil
Üdvözlet mindenkinek!
A fent nevezett CD lejátszóval vala az a gond, hogy csúnyán szól (folyamatosan vannak a kimenet szkópolásán vízszintes darabkák), és a vége felé a lemeznek már nem is nagyon találja a sávot (írott lemezzel).
Egy nagyon hasonló cd-optikás és vezérlős gép (philips ak796) hibátlan olvasása során a lemez forgása során a tracking folyamatosan mozgatja előre-hátra szabad szemmel láthatóan még egy fordulaton belül is. Viszont ez a CD380 már nem nagyon mozgatja. Ugyan a gyári lemezeket még tűrhetően játssza, de ha már felismeri az írottat, miért ne lehetne az is jól játszani?
Próbáltam a lézer erősségét állítani, a "mégnemjó" és a "márnemjó" között kb félúton, de ez nem nagyon hatja meg, illetve hiába állítom a hibás olvasás közben, nem igazán javul a kimenet minősége.
A lézeregység elektromágnessel mozgatja a fejet a lemez alatt (cd380) vagy fölött (ak796), így biztos, hogy ez a része működik, csak nem elég fürge, vagy valahol elveszik a szervó-jel.
Van valakinek ötlete, mi/hol lehet a hiba?
üdv,
ck
