I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
Van ez a fenti dragabb fajta erosito (10e euro !)-igen jol olvastatok :villa: A-osztalyu erosito 2x50W.
Forgo potenciometere az a vegtelen reedreles.tehat az nem hibazhat.
A hiba ugy 10perc mulva jelentkezik amikor bemelegszik de csak a bal oldalon:
pl mondjuk all 3 as erossegnel, felerositve 4-esre akkor lehalkul felire,5-nel visszajon 3-as szintre,6-oson, ismet lehalkul, majd 7-esen beall 7-re ahogy kell, nagyobb fokozatoknal mar jo.
Tehat ilyen ugrasok jonnek lepteteskor.
Javitanom helyszinen kell majd par nap mulva mert az erosito 63kg.
A vegerositon csak 4db elko van 470uF/100V a tobbi mind minoseges WIMA blokk kondi.
Talalkozott mar valaki ilyen hibakkal erositoknel?
Hello Mindenkinek!
Egy kis segitséget kérnék . Van egy szimetrikus kimenetü (XLR) DAC-om, az erősitőm meg asszimtrikus (RCA)bemenetü. Hogy lehetne ezt a problémát megoldani minőségvesztés nélkül? Az xlr-rca adaptert azt ismerem, más megoldást keresek.
Köszi :Hege.
Szép napot!
A fenti autórádióhoz szeretnék a hozzáértőktől egy kódot kérni.
SEZ2Z9F1011919
Valami Grundig gyártmány.
Nagyon szépen köszönöm a hozzászólásokat előre is!
