KONKA KP2107AST - VCT3831A , STRW6756 , TDA8177F , TDA2616 - SCH
575.2 KB
Looking for similar konka manual?
KONKA KP2107AST - VCT3831A , STRW6756 , TDA8177F , TDA2616 - SCH service manual (1st page)
Preview of KONKA KP2107AST - VCT3831A , STRW6756 , TDA8177F , TDA2616 - SCH [1st page]
    KONKA KP-2107AST VCT-3831A STRW-6756 TDA-8177F TDA-2616 KP2107AST VCT3831A STRW6756 TDA8177F TDA2616 KP 2107 AST VCT 3831 STRW 6756 TDA 8177 2616
Kiamo LCD2006WXTK
Sziasztok! Nemrég behoztak hozzánk egy Kiamo LCD2006WXTK készüléket. Azon kívül hogy a gyártóról nem hallott senki, még rajzot sem találtunk hozzá, több órás megfeszített keresés után sem! Tehát kérlek benneteket ha van valakinek birtokában kapcs. rajz, vagy be tudja azonosítani, az legyen kedves jelezni felém. Köszönöm!
EMERSON LC320EM3F WON'T START: SOLVED
:taps2: This is a LCD TV brand EMERSON, model LC320EM3F and is completely death. At first revision, we detected some bad components in the switching power source: Switching MOSFET K10A50D, RESISTOR 0.19 Ohm, 2W, transistor switching controler 2SC5344, Zener Diode 1ZB36 (36V) and the 4A fuse. I had the SM of LC320EM9 model, so, the values of the components are different. I replace them all twice and they always broke again! FRUSTRATING! Then I realyze that changin the values nearly to the LC320EM9 model, I would obtain better results (see FILE ATTACHED) I replace the 0.19Ohm resistor by a 0.39Ohm, maximizing the pulse received for the control transistor, for that purpose, also changed the 2.4KOhm resistor for 5.6KOhm. The switching MOSFET used was IRF640 replacing K10A50D, and transistor 2SC5344 was replaced by 2N5551. Finally we add a Zener diode not included in original board (marked with blue circle) limiting the colector voltage and gate voltage to 26V. For short, when we connect the power cord, every thing was fine, except than voltages at secondary of main transformer, was only 3.2V DC in all rectifiers. Found a diode in short-circuit (circled in red), replaced it and BINGO!, the TV return to live again!!!! I Hope it serves as a nice experience for the future.
Mikomi 15LCD250
Sziasztok! Mikomi ki LCD tv-be szeretnék eeprom tartalmat ha lenne valakinek. A hiba minden müködik csak nem tárolódnak a beállitások,pl adók,fényerő.A régen tárolt adók megvannak. Előre is köszi. Jó Munkát Mindenkinek!
Sharp 100Hz-es tv digit modul
Sziasztok! Prózai kérdés:két 100Hz-es tv(70es14 és 70gs64) digit modul felcserélhető-é.7242typ.számú egyik,7313számú másik.Csatik ua,de műkszik felcserélve? Köszönöm István
