KORTING RB3300W 1935 SCH
865.3 KB
Looking for similar korting manual?
    KORTING RB-3300W RB3300W 1935 RB 3300
SONY STR DE-698 bezáródott,nem lehet még RESET-elni sem
SONY STR DE 698 tipusú erősitőn nem lehet BEMENETET választani. Nem reagál egyik kiválasztógombra sem. Próbáltam RESET-elni az interneten megadott módon , de sajnos ugyanaz a helyzet, visszaáll a tiltott állapotba. Vajon elektromechanikai hibája lehet. esetleg valami védelem kapcsolja mindig vissza. Van valakinek valami ötlete ?
Kraus Kpr 100 előerősítő phono bemenet zajos.
Az esetleírásod egy kissé szűkszavú. Javítsd, mert különben törlöm.
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Autós CD váltó pótlása (helyettesítése)
Üdvözletem tisztelt Mesterek.Egyre többen érdeklődnek hogy gyári CD tár helyett lehet e USB vagy SD kártyát csatlakoztatni vagy mi a megoldás?Már láttam ilyen gépt,de én balga az ügyfél számát elveszítettem.Sokan a gyári gépet nem akarják cserélni, de a kazetta már elavút , a CD tár meg 50-100 Ez.Ft. És mindig csak CD. Amit említettem az SD-kártyás volt. Öreg Tom
