LG A510 A505 A410 A405 C400 BIOS DUMP
OTHER - EPROM
1.6 MB
EPROM
    LG A-510 A510 A505 A410 A405 C400 BIOS 510 505 410 405 400
LG PF1000U Ultra Short Throw Projector (chassis FM51E) Firmware
Good afternoon!
I'm looking for a dump for the LG PF1000U projector (chassis FM51E), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C).
There is no epk file available anywhere :(
This device attempts to turn on and responds to both buttons and the remote control:
It exits standby, runs the fans for 5 seconds, then spins them at 100% for another 5 seconds judging by the sound, and then goes back into standby.
The problem seems to be a corrupted NAND as it appears to me:
[ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3.3V 8-bit)
[ 0.110000] redirect_size = 400000, redirect_start = 7c00000
[ 0.110000] Loading nand bad block info(00000000+00020000)...
[ 0.119000] Mstar nand-flash partition definition
[ 0.119000] mtd info: # of partitions = 23
[ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3.3V 8-bit":
[ 0.119000] 0x00000000-0x00020000: "bbminfo"
[ 0.120000] 0x00040000-0x00060000: "mtdinfo"
[ 0.121000] 0x00160000-0x00760000: "rootfs"
[ 0.121000] 0x00760000-0x007c0000: "lginit"
[ 0.122000] 0x007c0000-0x007e0000: "crc32info"
[ 0.123000] 0x007e0000-0x00800000: "model"
[ 0.124000] 0x00800000-0x00900000: "logo"
[ 0.124000] 0x00900000-0x00a00000: "cmndata"
[ 0.125000] 0x00a00000-0x01200000: "nvram"
[ 0.126000] 0x01200000-0x01300000: "user"
[ 0.127000] 0x01300000-0x01400000: "ezcal"
[ 0.128000] 0x01400000-0x014a0000: "estream"
[ 0.128000] 0x014a0000-0x01620000: "opsrclib"
[ 0.129000] 0x01620000-0x018a0000: "kernel"
[ 0.130000] 0x018a0000-0x03560000: "lgapp"
[ 0.131000] 0x03560000-0x04fa0000: "lgres"
[ 0.132000] 0x04fa0000-0x05be0000: "lgfont"
[ 0.132000] 0x05be0000-0x05c00000: "tplist"
[ 0.133000] 0x05c00000-0x07640000: "lgres"
[ 0.134000] 0x00080000-0x000a0000: "cert"
[ 0.135000] 0x000a0000-0x00140000: "authcxt"
[ 0.136000] 0x00060000-0x00080000: "hdcp2"
[ 0.137000] 0x00140000-0x00160000: "keyrsrv"
[ 0.138000] mod_nand_init is invoked
[ 0.138000] GE driver inits
[ 0.138000] mod_iic_init is invoked
[ 0.138000] model option = 0xfc
[ 0.138000] Mstar_emac: [PHY Addr] ==> :0
[ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
[ 0.139000] RBQP_BASE = c44000
[ 0.140000] [SCALER][000173] _mod_scaler_init
[ 0.140000] [TTX_DRV][00508]init 170
[ 0.140000] MDrv_CC_Init
[ 0.140000] init 172
[ 0.140000] [DEMOD_DRV][00369]init 245
[ 0.140000] [BDMA_DRV][00629]init 251
[ 0.141000] TCP cubic registered
[ 0.141000] NET: Registered protocol family 17
[ 0.142000] RPC: Registered udp transport module.
[ 0.142000] RPC: Registered tcp transport module.
[ 0.142000] Adding user_initcall[0] = 0x803a1314
[ 0.142000] Adding user_initcall[1] = 0x803a1320
[ 0.142000] Adding user_initcall[2] = 0x803a66f8
[ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
[ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
[ 0.150000] Freeing unused kernel memory: 132k freed
[ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
[ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
[ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
[ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
[ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
[ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
[ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
[ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
[ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
[ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
Thank you in advance!
LG klíma PSC áramkör szerepe
Van egy inverteres LG klímám ami kommunikációs hibával megállt. Jobban megvizsgálva, a kültéri egység szerint F27es hiba, azaz a PSC hiba, azaz (Prospective short circuit (PSC) fault error; current to inverter compressor between
AC and DC converter circuit is too high) . A szervízrajz egyértelműen rámutat azokra az alkatrészekre amelyek hibásak lehetnek
és mérés után, valóban hibásak, zárlatosak is.
Ennek az áramkörnek a szerepére nem tudtam rájönni, mivel az AC L és az AC N hálózati feszültséget az egyik greatz irányítja és megy is tovább a inverter felé a másik greatz híd árama pedig egy IGBT. hez csatlakozik, mellyel a híd +,- polusait lehet" zárlatba" kapcsolgatni? Ez valami fázisjavító áramkör lehet, vagy mi a fene? A TLP251 egy optócsatolós meghajtóval van kivezérelve az IGBT, az optocsatolót meg a processzor vezérli a PSC on-off jellel.A tárgyalt áramköri részt pirossal jelöltem. Segítségeteket köszönöm előre is!
Tronic tlg 1000 akkutöltő
Sziasztok! Segítségre lenne szükségem.A fent nevezett töltőt bedugtam,hogy töltöm az akkukat de nem történt semmi.Csak ciripelést hallani.Szétszerelés után láttam,hogy kapcsolóüzemű táp van benne.Szükségem lenne kapcsolási rajzra vagy tanácsra,hogy mit cseréljek.Púpos kondikat nem láttam. Előre is köszönöm. Tisztelettel:Geri100
Panasonic SL-SX240 discman fejhallgató erősítő IC (műv.er.: NJU7082BV) helyettesítése
Sziasztok! Egy Panasonic SL-SX240 típusú discman fejhallgató erősítő IC-jének helyettesítése ügyében szeretnék segítséget kérni. A hibajelenség: az egyik kimeneti csatorna döglött. A hibát sajnos én okoztam... Kísérletezés közben véletlenül bement a most halott csatornán kb. 25 V. A lecke megtanulva, most szeretném rendbehozni. Amit idáig tettem: letöltöttem a service manualt innen az oldalról, megállapítottam, hogy az IC egy teljesítmény műveleti erősítő, nevezetesen NJU7082BV típusú. A műveleti erősítő bemenetén mindkét csatorna megvan, a kimenetnél viszont csak az egyik => a készülék többi része talán jó, a gond az IC. Az IC-t a New Japan Radio gyártja, ha még gyártja. Egyébként a digi-key-től lehetne venni néhány dollár + kb. 60$ szállításért. Sajnos a hivatalos magyar kereskedőnek nincs belőle készlete, a kedvemért meg nem rendelnek belőle. Az IC SSOP8 tokozású, eddig odáig jutottam, hogy talán az LM4808 lábkompatibilis, meg közel hasonló méretű lenne (VSOP8), csak rövidebb kb. 1,5 mm-el. Magamtól a következő lehetőségeket látom elképzelhetőnek: 1.: rendelek a digi-key-től (nagyon sok a szállítási költség), 2.: megpróbálok sample IC-t kérni (van sample szolgáltatásuk, csak a többi gyártóval szemben sokkal több info-t kérnek a leendő termékről, amit "építek" a sample segítségével), 3.: találok helyettesítő típust, (4.: találok Magyarországon elfekvő készletet.) Örömmel fogadnám a javaslataitokat.
