LIFESAT LS2400
SATELLITE - EPROM
1.1 KB
SATELLITE
EPROM
Looking for similar lifesat manual?
    LIFESAT LS-2400 LS2400 LS 2400
Relevant SATELLITE forum topics:
Yamaha KX-250 Cassettedeck output tick noise problem (electronic not mechanical)
There is no service manual of the Yamaha KX-250, anyone? I have fixed the mechanism of this unit, replaced the capstan motor (bad quality shreeking one with a better one), replaced the belts and works perfectly fine. Perfect audio, everything works great. However after testing it many times I reassembled the unit and did another test. Some tick noise is present in the audio.
The tick noise is present when executing a function, for example REW (most worse of all), FF or PLAY (only a few spikes randomly), also when using the remote. It is not a problem of the mechanism (motor) or a ground issue or something like that, disconnected it and problem still exists. Maybe it has something to do with static electricity because I have used the unit without HEAD cables attached to the mainboard (head input pins floating) however the pre-amplification circuit is working fine except of the noise. There are two IC's in this circuit, UPC1330HA head selector and a LA3161 pre-amplifier.
The LA3161 is a 2-channel preamplifier that has a circuit to reject ripple. Is it possible this IC is damaged (because of a (static) spike) and because of that the ripple rejection is no longer working? When I replace this IC the problem is solved?
Any ideas or do have some people any experience with this or recognize the sound behaviour discription? Anyone who can point me into the right direction?
Many thanks for any reply.
TEVION video jel átlővő
Sziasztok! Pár napja kaptam ezt a készüléket, egy napig rendesen ment, de most oldalról hullámos képet ad, hang rendben. Hogyan lehet eldönteni hogy a vevő vagy az adó a rossz. Nincs meg a vevő tápegysége, milyet érdemes hozzá szerezni, most egy sima 500mA-sel próbálom? Ha valaki találkozott már ilyennel segítsen. Ha leépítem a RF-modulátort a helyzet változatlan, cseréltem a betáp elkót, a 5V kondiját.
BNT-1000AP szünetmentes túlterheléses hibajelzés, terheletlenül is
Egyik barátom szünetmentesében cseréltem akksikat, mert tényleg rossz volt.
kb. ugyanaz ment bele 7Ah helyett 7.2Ah. Nem voltak teljesen feltöltve így nálam bekapcsolva hagytam a szünetmentest (1 napig kb.), rendben látszott minden.
Hazavitték és kb. 2 nap múlva beüzemelték, mikor is előjött egy hiba, hogy nem is minden indításkor, de nagyon sokszor túlterheléses sípolásos jelzést ad bekapcsolás után. De nem mindíg. Nyugtalanított, így ismét magamhoz vettem, mértem sok mindent, ellenőriztem a forrasztásokat, de nemigen találtam semmi hibát. A hibát nálam is random produkálja. Netes leírásokban azt láttam, hogy esetleg nem mindegy hogy milyen procedúra mentén kapcsoljuk be. Ez igaz lehet? Vagy lehet más gond is?
Elkók nem puffadtak...
A kontrolleren B801-V1.41 felirat van.
Ha valakinek lenne ötlete, megköszönném.
Laci
13W-os előtét
Üdvözlet mindenkinek! Végső elbizonytalanodásomban kérnék segítséget! Hozzám került,egy 13W-os konyhai fénycsőarmatúra,hogy "nem jó" Gondoltam döglött a cső!---Nem jött be! Kontakthiba---Ez se! Akkor előtét,és valóban.Csak az a baj,hogy nem "átlagos"kapcsolás,amit megszoktunk. -az mellett,hogy a két MJE13002 tranyó benne van,még található benne 2 diac és egy MCR100-6 os triac,plusz még egy tranyó,amin nincs jelzés,de mérve jót mutat! Az egyik 13002-es rossz volt,azt cseréltem.A tápszűrő 3,3m/400V-os kondival együtt! És mégse akarja a jót. Ha valakinek lenne ilyesfajta rajza,azt nagyon megköszönném!Sokat segítene a hibakeresésben,és a megértésben! Köszönetel Molnitron
