LOTUS FOUR-VALVE-AC DOUBLE RF-STAGES RECEIVER 1933 SCH
225.0 KB
Looking for similar lotus manual?
LOTUS FOUR-VALVE-AC DOUBLE RF-STAGES RECEIVER 1933 SCH service manual (1st page)
Preview of LOTUS FOUR-VALVE-AC DOUBLE RF-STAGES RECEIVER 1933 SCH [1st page]
LOTUS FOUR-VALVE-AC DOUBLE RF-STAGES RECEIVER 1933 SCH service manual (2nd page)
Preview of LOTUS FOUR-VALVE-AC DOUBLE RF-STAGES RECEIVER 1933 SCH [2nd page]
    LOTUS DOUBLE RFSTAGES RECEIVER 1933 FOUR VALVE AC RF STAGES RF-STAGES
Philips CD 104
Üdv Philips CD104-el szenvedek 1 napja, minden működik csak hang nem jön ki belőle, de ha a reed relés zajzár reedjeit átkötöm egy vezetékkel akkor szól szépen és tisztán, esetleg ötlete valakinek?
JVC CA-MXKB2 Locked
Sziasztok! A fent említett hifi, most már működik, csak a CD rész nem indul, mert ha megnyomom az open gombot azt írja a kijelző hogy LOCKED, mi a fene lehet vele, meg forgatja a lemeztartót, fejet is megemeli. Segítségeteket előre is köszi!
RCF art 415-A speaker - PSU not working
Hello everyone,
I've this speaker model:
RCF art 415-A.
The power supply is faulty, no votltage out to the amplifier.
The Mosfets are blown. I've changed the mosfets and it's driver, and still have a problem.
I tried to switch on but only one of the mosfets gets hot (the one which switches the 310. There are 2 of them - Mos5 in the scheme).
Obviously I turned it off.
1) What causes it to heat?
2) Testing the VCC of the LMC555, it's only 2.7V. When taking it out of the circuit, it's 12VDC! What makes the voltage to drop. Where does the supply of the LMC555 come from? The VCC of the 555 should be around 10V, as compared with a good card.
I've changed the 555, but the problem remained. I've checked the components around, resistors and capacitors, and transistors, and seem to be OK.
4) The VCC of the Mosfet driver is 10V, but should be 12V if compared with a good card.
3) Could the trafo be damaged? Are these parts reliable or may blow up?
4) What is the purpose of the optocoupler in the circuit?
I would really appreciate any help.
I didn't find the 100% schemes for this RCF (400), but found a very similar one (The 600 version).
name and a link here to download the pdf.
DigiPRO600B
https://elektrotanya.com/db-technologies_digipro600b_sch.pdf/download.html
Regards and many thanks
Philips minihifi tipus F 1395/62 javitása
Üdv mindenkinek.
Kérnék egy kis segitséget a fentemlitett minihifi javitásában.
A készüléket sok idö után vettem elö,nem volt használva,gondoltam kitakaritom elinditom.
Inditásnál rádio,erösitö,hangszinszabájozó ok.
A kazetta része lejátszáson a csévélö csonk nem forog,tekerés megy mind a két irányba.
Szétszedtem és a fogaskerék ami kapcsolodik a csonk és a hajtótengely közzé le van darálva a fogai,logikus ,hogy nem forog.
Ha van valakinek ilyen mechanikája vagy  fogaskerék vagy valamilyen módon tudna segiteni Szépen köszönném.
Tudom a készülék nem egyy csúcskategória,de nekem megérné megjavitani,sajnálom szétszedni vagy kidobni.
Próbálok képeket is feltenni mert úgy könnyebb beazonositani ,hátha van valakineg elfekvöben alkatrésze.
