MARANTZ DV7600 MZ06-007
VIDEO-DVD - INFO-TIPS
130.1 KB
INFO-TIPS
MARANTZ DV7600 MZ06-007 service manual (1st page)
Preview of MARANTZ DV7600 MZ06-007 [1st page]
MARANTZ DV7600 MZ06-007 service manual (2nd page)
Preview of MARANTZ DV7600 MZ06-007 [2nd page]
    MARANTZ DV-7600 DV7600 MZ06007 DV 7600 MZ 06007 MZ06 007 MZ06-007
Panasonic video capstan motort keresek
Sziasztok! Capstan motort keresek panasonic Z" mechanikához. Pl: NV-HD630 ; NV-HV50
Sony Sl-S770 vcr interrupted playback and AV display issues
I'm encountering an issue with my Super Betamax player. During playback, some cassettes abruptly stop playing at seemingly random points, accompanied by a sound similar to the one made when a tape reaches its end. This interruption also renders the rewind and forward buttons unresponsive. However, it does not impede the manual forwarding or rewinding of the cassette. The only solution seems to be ejecting the cassette and reinserting it. Occasionally, even this workaround fails, allowing only two seconds of playback before the problem recurs.
I sought guidance from the Mister Betamax troubleshooting page, which indicated that the tape safety device might be the root cause. I received additional advice suggesting that the issue could stem from one of the sensors within the VCR, possibly due to oxidized contacts causing intermittent operation. It was recommended to resolve this by carefully cleaning the contacts on the sensor switch responsible for detecting loaded tapes or the sensor that detects if the tape is "record-protected." Another suggestion was to monitor the output of these switches using an oscilloscope or voltmeter to determine if they are indeed the source of the problem.
I'm eager to hear if anyone has additional advice or personal experiences to share regarding this issue.
Additionally, I'm facing an AV cable problem where the yellow AV cable fails to display any video. While it used to work correctly, the AV audio cable still functions properly. As a temporary workaround, I've been using a coaxial cable and routing it through another VCR to utilize its AV output. However, I'm interested in exploring potential solutions to fix the issue with the yellow AV cable, if possible. Any insights or suggestions would be greatly appreciated.
FUNAI DDVR-5800 bekapcsolási/betöltési gondok + kijelző sem működik.:( LEZÁRVA.
Sziasztok! A fent szereplő combóhoz segítséget szeretnék kérni: Azt csinálja, hogy bekapcsolás után kb. 5 másodperc múlva kikapcsol. Ezt akkor is megteszi, ha DVD/CD lemezt szeretnék betenni. Bekapcsoláskor a LED-ek megfelelően világítanak. A kazetta behelyezése kriminális, egyébként, ha sikerül, tökéletes a kép, a hang. Tehát: 1. Kazetta belyezése a nyílásba. (hiába nyomnám tovább, nem megy, így nem kapcsol be.) 2. Bekapcsolás, ("function" gomb megnyomása) 3. Ekkor tovább lehet nyomni a kazettát és be is tölti, indul a lejátszás. Szétszedve azt lehet látni, hogy a betöltö motor "ráfeszít" a betöltő mechanikára, ha ki van kapcsolva. Ellenben bekapcsoláskor "kilazul", alapállapotba kerül a mechanika. Letöltöttem a doksiját. A kijelző két szélső kivezetésének feszülségét szerettem volna megtudni, de a rajzon nem szerepel érték. Én -17,2 és -15,7V-ot mértem. A többi feszültséget még nem ellenőriztem. A tápegység részében nincs kondi felpúposodva. Bocsi, ha hosszúra sikerült... ;) Üdv: Födi LEZÁRTAM. A készüléket visszaadom.
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrész!
SONY SLV-E 170,150,580 betöltő motor tengelyén lévő műanyag elrepedős alkatrészt honnan lehet beszerezni?
