MARCONI TF-1064B-5 68-185 450-470MHZ VHF SIGNAL GENERATOR 1963 SM
METER - SERVICE MANUAL
15.7 MB
METER
Looking for similar marconi manual?
MARCONI TF-1064B-5 68-185 450-470MHZ VHF SIGNAL GENERATOR 1963 SM service manual (1st page)
Preview of MARCONI TF-1064B-5 68-185 450-470MHZ VHF SIGNAL GENERATOR 1963 SM [1st page]
MARCONI TF-1064B-5 68-185 450-470MHZ VHF SIGNAL GENERATOR 1963 SM service manual (2nd page)
Preview of MARCONI TF-1064B-5 68-185 450-470MHZ VHF SIGNAL GENERATOR 1963 SM [2nd page]
    MARCONI TF-1064B-5 VHF SIGNAL GENERATOR TF1064B5 68185 450470MHZ 1963 TF 1064 450470 MHZ 1064B 68 185 450 470MHZ 68-185 450-470MHZ
Relevant METER forum topics:
Marconi TF 2008 repair
Some months ago I bought a Marconi TF 2008, I knew that the instrument not was fully functional. When I started faultfinding I realized that the wiring was wery complex. By help of schematics that can be downloaded from many sites I started to sort out the wiring between all the modules in A30. It took quite a while but was to great help when I started the faultfinding. First of all I replaced all electrolytic capacitors, found several capacitors that were broken. The main problem was that the Carrier range positions 2, 6, 8 and 10 did not work. The problem for range 2 was an broken inductor L1, in module A8. The fault for range 6,8 and 10 was a broken connection between R4:s center pin and R3 in module A23 (bad soldering). To help anyone with faultfinding I share my ownmade drawings in the attached PDF.
MARCONI TF2008 signálgenerátor moduláció hiba
Tisztelt olvasók ! Van nekem egy MARCONI 2008 tipusú signalgenerátorom. Kettő probléma van vele A bekapcsoláskor a frekvenciát szépen tartja. Azonban moduláció egyáltalán nincs. Sem AM, sem FM módban.Lehet hogy kapcsoló kontakt hiba? Kapcsolási rajzot nem találtam a neten. Melyik része lehet hibás ? A másik probléma kontakt hoba a kimeneti jelszínt kapcsoló mozgatásakor jelenik meg a kimeneti jelszint. Valaki szedte már szét , mennyire lehet kontakt spray- vel befújni. Üdv. Tibor
