MARCONI TF2169 PULSE MODULATOR FOR 2015 GENERATOR 1974 SM
METER - SERVICE MANUAL
4.1 MB
METER
Looking for similar marconi manual?
MARCONI TF2169 PULSE MODULATOR FOR 2015 GENERATOR 1974 SM service manual (1st page)
Preview of MARCONI TF2169 PULSE MODULATOR FOR 2015 GENERATOR 1974 SM [1st page]
MARCONI TF2169 PULSE MODULATOR FOR 2015 GENERATOR 1974 SM service manual (2nd page)
Preview of MARCONI TF2169 PULSE MODULATOR FOR 2015 GENERATOR 1974 SM [2nd page]
    MARCONI TF-2169 MODULATOR FOR TF2169 PULSE 2015 GENERATOR 1974 TF 2169
Relevant METER forum topics:
MARCONI TF2008 signálgenerátor moduláció hiba
Tisztelt olvasók ! Van nekem egy MARCONI 2008 tipusú signalgenerátorom. Kettő probléma van vele A bekapcsoláskor a frekvenciát szépen tartja. Azonban moduláció egyáltalán nincs. Sem AM, sem FM módban.Lehet hogy kapcsoló kontakt hiba? Kapcsolási rajzot nem találtam a neten. Melyik része lehet hibás ? A másik probléma kontakt hoba a kimeneti jelszínt kapcsoló mozgatásakor jelenik meg a kimeneti jelszint. Valaki szedte már szét , mennyire lehet kontakt spray- vel befújni. Üdv. Tibor
Marconi TF 2008 repair
Some months ago I bought a Marconi TF 2008, I knew that the instrument not was fully functional. When I started faultfinding I realized that the wiring was wery complex. By help of schematics that can be downloaded from many sites I started to sort out the wiring between all the modules in A30. It took quite a while but was to great help when I started the faultfinding. First of all I replaced all electrolytic capacitors, found several capacitors that were broken. The main problem was that the Carrier range positions 2, 6, 8 and 10 did not work. The problem for range 2 was an broken inductor L1, in module A8. The fault for range 6,8 and 10 was a broken connection between R4:s center pin and R3 in module A23 (bad soldering). To help anyone with faultfinding I share my ownmade drawings in the attached PDF.
