MP-2 OROSZ RADIO SCH.
16.7 KB
Looking for similar mp manual?
    MP-2 RADIO SCH. MP2 OROSZ MP
advice for repairing a DBX BX3 power amp (fused power transistor)
i have a very nice vintage DBX BX3 amp on which at least one channel fused.
power transistors literally burned down.
it is a very nice piece of hardware (4 channels with BTL capability 4x125W or 2x300W)
I would like to fix it myself. Having an electronic engineering degree, i think I should be able to undertake that venture but I never practiced (i've been in software for the last 40 years...)
So I need some guidance on the methodology to diagnose and track what went wrong.
I do have a scope, signal generator and I guess all required tools, as well as the schematics of the amp.
what I need is some help on locating the key parameters to measure and how to incrementally explore the different stages of the amp to find the faulty sections.
I guess I need to isolate the different sections of the amp but then, what ?
any help and advice will be highly appretiated.
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
Audio Amplifier BST XA-1000
Hi
I'm looking for a schematic diagram for this equipment:
Professional Power Amplifier XA-1000
The main fuse was blown and according the owner it blowns again after replacement.
He used a 40 amp fuse. The original fuse is not around anymore and there is nothing written outside on the label. So it's somewhat a lottery about the correct fuse rating.
Anyway, I would like to repair this equipment but without a diagram it would be a pain and nearly impossible.
Tryed to find a diagramwith Google search - negative. Also the manufacurer ist unknown this days.
Maybe a reader has more information aboutb this.
Thanks a lot
Redwood (74)
https://www.simplysoundandlighting.co.uk/bst-xa1000-1000w-power-amplifier
JVC Power Amplifier KS-A201J dióda
Tisztelt Uraim! Barátom erősítőjében a +, - között van ez a bizonyos dióda, mely valami oknál fogva felrobbant. Szerinte jó polaritással kötötte be a tápot. Ki tudja? Méretét tekintve jó vastag, kb 6 m/m.Ami megmaradt belőle azon csak egy 3- as, illetve alatta vastagabb 8- as látszik. Ezek lettek volna a kiindulásai a megjelölésének. Kérdésem, hogy mi a kritériuma más típusú dióda beépítésének? Sajnos csak ilyen képet tudtam készíteni a maradékról. Ideiglenesen bele raktam egy fiókban talált diódát,melyet egy számítógép tápból mentettem. Kipróbálva az erősítőt működik rendesen. Kérem szíves segítségüket, melyet előre is köszönök! Üdvözlettel: Gaibali
