MURPHY TU 504 A 110 [SCH].
209.7 KB
Looking for similar murphy manual?
    MURPHY TU 504 110 [SCH].
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
Magassugárzó bekötése hangváltóba helyes polaritással (megoldva)
Hali! Van egy régi hangváltóm, ahol a magasnál van egy tekercs, egy kondi meg egy ellenállás. Gondolom 12db/oktávos a szűrő. A kérdésem az, hogy mindenféleképpen ellentétes polaritással kell bekötni a magasat, vagy sem? Mi a magyarázat? Már sok mindent hallottam, ezért elbizonytalanodtam. A magassugárzó egyébként dóm, 8ohmos. A neve Monacor-DT-107. Előre is köszi. Karcsi
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
PIONEER XR-A550 HIFI TÁVIRÁNYÍTÓ PÓTLÁSA, HELYETTESÍTÉSE.
Szeretném pótolni ezt a távirányítót. Sajnos elveszett.
Típusa: CU-XR048
A távirányító képét csatoltam.
Ha valaki tudna segíteni benne azt nagyon megköszönném.Esetleg ha a helyettesítő típusát tudná megadni az is jó lenne.
Természetesen nem kívánom ingyen.
