NAD C370 HEADPHONES SERVICE INFO
49.3 KB
Looking for similar nad manual?
NAD C370 HEADPHONES SERVICE INFO service manual (1st page)
Preview of NAD C370 HEADPHONES SERVICE INFO [1st page]
    NAD C-370 INFO C370 HEADPHONES 370
NAD 3140 amplifier - power transistors getting hot
This one had been sitting in a barn for years. Powered it up and the large power transistors on the heat sink would get hot
after a time....and the heat sink would also get quite hot. Speakers sounded like they had some DC on them....with a loud thump
Found the manual on Hi-Fi engine,
http://www.mediafire.com/file/b8mlsu7q3pz0bvf/hfe_nad_3140_service.pdf/file ]
and saw a video on youtube saying lots of capacitors dry out
due to their locations near resistors that get very hot, I guess sorta a poor
design. Went in and recapped almost the entire
product save for the (4) large 50V PS caps which appear to check ok.None of
the high power or driver transistors
mounted to the main heat sink were shorted..
Powered on but no audio, and noticed the fuses to Bridge D805 were melted open.
I believe they were ok before.
Replaced them and they started to light up like fiilaments, so shut down,
removed the bridge D805, then checked it, its ok.
There is about a 16 ohm short on the + / - lands where the bridge was. It
seems like something I did maybe is causing this,
like a capacitor in backwards, which I am doing alot of lately for some
reason.
Turns out, yep I put C805 (470/ 63) In backwards ! Capacitor still checks
ok, so will re-use it.
Short is still there though Im guessing R803 is adding in 5.6 ohms or so,
that means theres a 10 ohm short someplace. Q801, 802 arent reading short,
and looks like this becomes a +43V ps feed.
Any ideas out there on what to check next? I am guessing this cap in
backwards caused the voltage applied to a component to be
reverse and its shorted. Or would this be normal with a reversed cap installed,
and putting it in right would be how to fix it?
Steve Hearns
Technotronic Dimensions [USA]
WWW.TECHNOTRONIC-DIMENSIONS.COM
NAD 5120 bakelit lemezjátszó brummot gerjeszt JVC MX-G90R receiverben (MEGOLDVA)
Kedves Hozzáértők! Segítséget kérek a lemezjátszóm témájában. A címben szereplő lemezjátszót megmentettem az enyészettől (bevallom kukáztam, de még a kidobó kezéből sikerült kivennem). Darabokban volt, összeraktam. Tettem bele Ortofon OM-5-ös pick-up-ot. Lecseréltem a DIN csatlakozóját RCA-ra. Működik, szól, de amivel nem tudok mit kezdeni, az az, hogy brummot küld az erősítő bemenetére. Ha be van dugva, de még nincs bekapcsolva már akkor is, elég nagy jelszinttel. Ha bekapcsolom, akkor leesik a brumm szintje, a hasznos jel aránylag el is nyomja, de akkor is észrevehetően ott van. Észre vettem, hogy javítás közben a mechanika test vezetéke leszakadt. Visszaforrasztorttam, de nem lett ettől kissebb a brumm szintje. Készítettem egy földelő kábelt, amivel az erősítő dedikált test pontját lekötöttem a konnektor föld pontjára. Ez sem igazán segített. Mondjuk a lakásban nincs igazi föld, mert a betápnál össze van közösítve a konnektorok összegyűjtött földvezetékei a nullával (lakótelepi lakás). Az egész jelenségben azt nem értem a leginkább, hogy mitől csökken le a brumm szintje, amikor bekapcsolom a lemezjátszó motorját. A motor áramköreinek semmi köze a hangszedőhöz, teljesen szét vannak választva elektromosan/galavanitikusan. Van erre valakinek használható ötlete? Előre is köszönöm! Gábor A témát továbbképzés szükségessége miatt feleslegesnek és lezártnak tekintem. Köszönöm! Gábor Megoldás: A lemezjátszónak jót tett a sok törődés, de alapvetően az erősítő felett trónoló CRT TV elektromágneses zaja akasztotta ki a PHONO bemenetet. Áramtalanított TV mellett szépen elcsendesedett a zaj.
NAD 5120 lemezjátszó felujítás
Van egy NAD 5120-am két csőkarral, MC10/T-10 mc pickuppal és trafóval, de már sok baja van. Tartalék ékszíjam van hozzá, viszont ki kéne cseréljem a motorját, mert már kattog. Sehol nem találok ilyet. A motor megegyezik a TESLA NC470 és a Lenco L800 lemezjátszó motorral, de így sem találtam. Más. Kéne a csőkar csillapítójába szilikon olajat töltenem, de nem tudom pontosan a viszkozitását. Hol lehet ilyen szilikon olajat venni? üdv.
Nad 3020 RIAA korrektor nyák gyártás
Lenne itt Valaki, aki ezt jó minőségben le tudná gyártani? Esetleg egy jó ötlet e-helyett? Aztán érdekelne még egy jó hangszínszabályzó is.
Köszönöm!!
