NAGRA 4.2 SM
27.1 MB
Looking for similar nagra manual?
NAGRA 4.2 SM service manual (1st page)
Preview of NAGRA 4.2 SM [1st page]
NAGRA 4.2 SM service manual (2nd page)
Preview of NAGRA 4.2 SM [2nd page]
    NAGRA 4.2
Kenwood KA-3500 Integrated Amp BIAS Adjust
Hello, Last week I picked up a nice Kenwood KA-3500 40watt intergrated amplifier in pretty good shape. Upon using it a bit more, I noticed a bit of distortion at high volume, more so in the left channel. I checked the DC offset at the speaker terminals, and the L channel said 100 mV, while the R was 25 mV. I understand this isn't so good for the L channel at least, but unfortunately this amp doesn't have any DC offset adjustments. Am I right in saying that to fix this I'd have to replace the output transistors? -- On a related issue, in the service manual I found the section on BIAS adjustment, and I read online how it can affect the DC offset. So I hooked up my voltmeter to the test points, and I got 4 mV on the L, and 8 mV on the R. In the manual it says should be 40 mV.....(!). Is there something wrong here? I tried carefully adjusting them, but they only go to 30mV with the pots fully on, this doesn't seem right to me. -- I compromised at 20 mV BIAS for both channels, and now the DC offset is 50 mV for L, and 5 mV for R, which is better, less than half what they were. I'm wondering, will I damage anything doing this, should I put them back to where they were? -- The service manual is on site here. Let me know if you want me to upload an english copy of the Owner's Manual, it has a better schematic in it all on one page, easier to read. I've also included some pictures. They're not my actual unit, but mine is exactly the same, but less dusty. -- Thanks for reading this. Many thanks in advance, and have a peaceful Palm Sunday! :taps2: Bellarmine
YAMAHA RX-V3900 púpos kondi
Üdv mindenkinek!
Hosszú évek szolgálata után, ma megbontottam az erősítőt, mivel a hangerőszabályzó megbolondult. Ezt helyrehoztam, viszont a képen látható hibát tapasztaltam.
Sajnos az egyik 71V 18000uF-os kondi púposodik. A kérdésem az lenne, hogy van-e megbízható hely, ahonnan rendelni lehet? (alit mellőzném, olcsó, de ki tudja, hogy mennyire fake terméket küldenek)
Vagy esetleg tudtok ajánlani valami csere típust, ami jó lehet bele?
Harman Kardon AVR 355 Nem kapcsol be,sötét a kijelző led sem világít
Sziastok, Harman Kardon AVR 355 nem kapcsol be,sötét a kijelző led sem világít viszont halk kattanás-l meghúz egy relé tápok rendben,púpos kondik nincsenek. "Az a helyzet az sajna mostanában nincs időm és lehetőségem a javításra ha lenne valaki aki Budapesti esetleg 13.ker és szomszédos kerületi és bevállalná a javítást persze nem ingyen írjon PÜ-t. Előre is köszi!"
Logitech erősítő néma
 Egy Logitech  (M/N: S-00076B
                         P6N: 880-000130
Speaker system Z523)
erősítő néma.
Még nem volt ilyen a kezemben. Van VGA csatlakozója, aminél a felirat: R out, és van egy RCA kimenet, amin L out a felirat. Azon kívül RCA  L és R in csatlakozók vannak rajta, (bemenetek). Gyanítom, hogy ez csak számítógéppel összekötve szólalna meg...
Tudna valaki segíteni, hogy hogyan lehetne megszólaltatni, vagy leellenőrizni, hogy működik-e, ha egyébként jó a készülék. A végfok IC-je STA 540, az előerősítő IC-k: két db 4558 műv. erősítő.
Köszönöm a segítséget!
Üdvözlettel:
