Kipukkant ebben a magnóban HA13001-es sztereo végfok IC, kölcsönadták valakinek az meghosszabbitotta, a drótok kopaszon toldva lettek es összeértek, az IC ára rettenetes nem ér az egész magnó annyit.
![](http://www.ocasiao.pt/sites/default/files/text_ad/2012/2012-07-02/IN31265153-img441.jpg)
Legalabb egy 500 sémát atneztem hogy talaljak helyette valamit, vegul is legjobban hasonlit a HA1394 (2 EUR) ugyanazok a tápok,bemenet, kimenet meg a tok is ugyanaz. Egyedul az pin1-es lab nem testre megy hanem 100uF-en keresztul megy a testre,pin6 tesre megy.
Bekötöttem a HA1394-et es meg se nyikkan, pin3,4 bemeneten van jel, gondoltam biztos rossz az IC, IC kivesz masik mas szerias betesz ugyanaz a helyzet.
Nagyobb jelszintu jelet adtam neki akkor nagyon halkan torzitva recsentget..Tápja egyoldalas 17V, ez megfelelô, hangszórók jók.
HA1394:
![](http://www.electronica-pt.com/db/imagens/HA1394.jpg)
HA13001:
Hello.
here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494.
In order to sell this amplifier I had to check if all the outputs and all the functions works properly.
On the back of this amplifier you have to frontal output : A and B.
I connect a pair of speaker on A output : no problem. I can adjust volume.
when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize.
With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated.
I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays.
I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly.
here is my experience in repairing an amplifier
Sziasztok. Grundig R25 tipusu rádióhoz keresek kf-erősitő modult, vagy TCA 420 A, és MC 1310 IC-t.Üdv. Solyom
Került hozzám egy ismeretlen előéletű Sony TA-F317R típusú erősítő "javításra" de úgy néz ki, hogy nem is volt neki semmi baja azt leszámítva, hogy hiányoznak róla a hangerő, mély, magas, balansz szabályzó gombok. Ez speciel
így néz ki, de nem hiszem, hogy ezek a gombok nagyon típus specifikusak volnának, jól jönne, ha volna valakinek rávaló gombok.
