NEO V2121CB
TV - EPROM
775.0byte
EPROM
Looking for similar neo manual?
    NEO V-2121CB V2121CB 2121 CB
LED TV NEO LED-2202FHD It does not work, the front LED off ,power supply is OK
Mark:NEO LED-2202FHD
Model:LED-2202FHD
Chassis (main board, components): 17MB60-3 flash 25Q80
LCD Screen/Panel :: LC215EUN (SC) (A1)
More informations:   Power supply 17PW05-2
   _SN : 6694377 100624
It does not work, the front LED off, the power supply is ok.It was software on usb several times, periodically every 2-3 months and it worked, finally it was left with the st.by LED off, that's why I-m thought about flash memory. Thanks a lot!
Neovo EPT 4210 AP-hez plazmához keresek távot_Megoldva IRC81758
Sziasztok, a fenti plazmához keresek távot, ill. IRC számot stb. A Belson BSV 4251-el ekvivalens, ha minden igaz. Köszönettel. Imre
neovia neo-2005dtx
Üdv mindenkinek! Tudna valaki segíteni, egy Neovia NEO-2005DTX-hez, vettem egy Medion MD83388 típusú univerzális távirányítót(az eredeti elveszett), de nem találom a megfelelő kódot. Köszönöm fblaci
NEO TV-2132TX.
eeprom tv NEO TV-2132TX..procesor:TDA9352PS.N2.3I
