I have a Yamaha CDX-590 CD player and it skips on some CDs - original CDs, these CDs play without problems on my other CD players.
I have changed the laser unit (KSS-210A) but this didn't solve the problem.
When I turn the player upside down, it plays the problematic CDs without a problem.
That's why I think the laser needs adjustment.
I have only a service manual for the CDX-493/593 but they should be very similar to the CDX-590.
It seems that the adjustments are done via "test mode" of the CDX-590, unfortunately there is not much information, how to exactly, in the service manual.
Here is a picture of the PCB.
http://www.volny.cz/hwtest/PCB.JPG
Here are the "test mode" sections of the service manual.
http://www.volny.cz/hwtest/TM1.GIF
http://www.volny.cz/hwtest/TM2.GIF
In "test mode" I have tried Auto adjustment mode 1, 2, 3, but I don't know if it should work fully automatic without any intervention or when the mode is fineshed and I can proceed to the next one.
So I activated mode 1, waited a while, activated mode 2, waited a while, activated mode 3, then exited test mode.
It didn't help.
Mode 1 - only a short blink of two horizontal dashes on the display and thats it
Mode 2 - started "play" without sound from a strange time 99:00 (the test CD is not so long), after a while it skips to another time, "plays" a while, then skips back and "plays" and so on, I left it about an hour and it was still going on
Mode 3 - seems to be very short as mode 1
I think I'm missing something ...
Maybe someone did this or even serviced Yamahas in an official service and can provide information how to adjust the laser?
Or maybe the problem is not the laser?
A fent nevezett erősítővel a következő a gondom:
Konnektorba bedugva és utána egyből bekapcsolva tökéletesen működik, kikapcsolás után rögtön visszakapcsolva is bekapcsol.
Ha nem egyből bedugás után kapcsolom be, hanem várok 2-3 percet, vagy a kikapcsolás után szintén várok 2-3 percet, már nem hajlandó visszakapcsolni. Kihúzva a konnektorból 2 perc várakozás után az első procedúrát végrehajtva minden gond nélkül működik.
Van valakinek erre valami ötlete, tapasztalata a javítását illetően?
A rajza fent van itt a tanyán, úgyhogy az elvi segítség megvan, csak a hirtelen ráérzés hiányzik.
Minden segítséget előre köszönök.
Krisztián
Nagyon régóta itt van nálam ez az erősítő, aminek a hangerő-szabályzó potija tönkrement. Ki lehet ezt váltani natúr sztereó potival? Csak azért, mert ez több lábas, igazából nem tudom milyen fajta nem mélyedtem el benne teljesen.
Üdv Mindenkinek!
Kaptam két Sony mini HIFIT. Az egyik Sony CMT-ED1A, annyi hibával, hogy a CD lejátszás közben akadozik, újraindul. Ehhez keresek esetleg feleslegessé vált remote controllert.
A másik Sony PMC-R30L, ennél minden rendben működik, csak a kijelzőnek nincs háttérvilágítása. Megbontás előtt kérnék szépen tanácsokat a szereléssel kapcsolatban. Előre is köszönettel : multifilter
