ONKYO A-7040 INTEGRATED AMPLIFIER SM
757.9 KB
Looking for similar onkyo manual?
ONKYO A-7040 INTEGRATED AMPLIFIER SM service manual (1st page)
Preview of ONKYO A-7040 INTEGRATED AMPLIFIER SM [1st page]
ONKYO A-7040 INTEGRATED AMPLIFIER SM service manual (2nd page)
Preview of ONKYO A-7040 INTEGRATED AMPLIFIER SM [2nd page]
    ONKYO A-7040 AMPLIFIER A7040 INTEGRATED 7040
ONKYO TX-SR444 házimozi erosito hibakód
Sziasztok. Ismét egy erosito kérdéssel fordulok hozzátok. Az ONKYO bekapcsolás után tutatja hogy milyen a hang beállitás /Volume 14/ és utánna bejon ez a hibakód amit a képen is lehet látni. Tudnátok segiteni ilyenkor mi a teendo? Koszi a válaszokat.
Udv: Gyuri
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Onkyo tx-sr500 nem jön ki belőle hang
Hozzám került egy Onkyo TX-SR500 erősítő, nem jön ki belőle hang. Bekapcsol, kezelőfunkciók működnek, de hangot sehogy nem ad. Oszciloszkóp nélkül nehéz...Tápok szerintem megvannak mindenütt. Valaki nem találkozott ilyen hibával? Gyanakszom a bemenet választó IC-re.
onkyo tx-ds494
Sziasztok! A segítségeteket szeretném kérni a fent nevezett erősítővel kapcsolatban. Minden működik rajta, de nem jön ki belőle semmi hang. Az egyik ismerősöm hozta, hogy nézzem meg neki, ugyanis a felesége mindig letakarja a szellőző nyílását a tetején egy terítővel mondván biztosan leégett a végfoka. A végfokait megmértem mind jó. Mi lehet a baja? És nem igazán akar működni rajta a hangerő gomb sem (sokszori körbetekerés után 1-et változik) a távirányítóval tökéletesen működik.
