ONKYO CR-N755 SM PARTS REV2
3.1 MB
Looking for similar onkyo manual?
ONKYO CR-N755 SM PARTS REV2 service manual (1st page)
Preview of ONKYO CR-N755 SM PARTS REV2 [1st page]
ONKYO CR-N755 SM PARTS REV2 service manual (2nd page)
Preview of ONKYO CR-N755 SM PARTS REV2 [2nd page]
    ONKYO CRN-755 REV-2 CRN755 REV2 CRN 755 REV CR N755 CR-N755
ONKYO TX-DS494 low volume problem solving experience
Hello. here is a message to share my experience in solving a problem that appeared on the home-cinema amplifier ONKYO tx-DS494. In order to sell this amplifier I had to check if all the outputs and all the functions works properly. On the back of this amplifier you have to frontal output : A and B. I connect a pair of speaker on A output : no problem. I can adjust volume. when i connect the pair to the b output and turn the volume knob no sound came out of the speakers until I reach a level defined by I don't know what. :hmmm: My volume level goes from 0 to 80db ( if I remember well ). from 0 to 23 db no sound and when I reach 24 dn sound increase and stabilize. With hearphone connected, i don' have this problem so I conculde that amplifing transistor could not be incriminated. I checked on the service manual and saw that there are two or three component that could be the source of the problem : the main processor, some capacitors on the output PCB and relays. I began testing capacitors: no pb. then I thought that if cannot be the main proc because it ( I think ) works in a binary mode: it works or it doesn't. so I decided to switch between themselves the two relay and :super: : it works. The relays was in fault and did not switches properly. here is my experience in repairing an amplifier
Onkyo TX 7730 receiver hálózati trafó feszültségek
Sziasztok, javithatalanul tönkrement az ebben levő trafó (NPT-1068G a trafó tipusa), hozzáférhetetlenül elszállt a hőbiztosítéka. Ráadásul a trafó (gondolom a búgásmentesítés miatt) végig van hegesztve... Nem találok sehol a trafó szekunder feszültségeiről adatot, igy nem tudok másikat beletenni. 3 független szekunder tekercse van, az egyik középleágazásos. Ha valaki tudna iránymutatást adni ( ahogy Lenin kérdezné: "Что де́лать?") nagyon köszönöm előre is !!
ONKYO TX-7430 fél óra múlva elszál az egyik oldal
Sziasztok! Ezzel az erősítővel van gondom, most került vissza hogy elugrott az egyik oldala, át mérve minden rendben találtam, kivéve a két végfok tranyót az egyik oldalon. Csere után járattam, és fél óra után pattanás és hang elment. Megint szétszed, átmér, hibás megint a két tranzisztor ( Q508, Q509 ) mást megint nem találtam ellenállások jók, a többi tranzisztorok is jók, most szól de nem merem próbálni. Mi lehet a gond?
Onkyo TX-NR414 erősítő, nem lehet bekapcsolni
Van egy Onkyo erősítő, melynek hibája, hogy nem lehet bekapcsolni. A készenléti panelra rámértem biztosíték jó, a kimenetén a 12vés a 9v megjelenik. Ez a tápfesz rácsatlakozik a HDMI panelra. Szerintem ezen a panelon kellene a hibát keresni, innen jön vissza az a kapcsoló jel, amelyik a készenléti relét kapcsolná a rajz szerint. Kérnék egy kis segítséget a hiba feltárásához.
